Compressor went out, replaced and car still will not rise
Old Dec 7, 2016 | 10:51 PM
Lil754boy's Avatar
E500
My compressor continued to run after I shut the car down. It ran for a while and finally had a horrible smell and stop. I read online, compressor. I ordered the compressor and replaced. The car still will not rise. I don't know the exact relay but i have swapped and replace many in the box. Which relay is for the compressor. Will a relay from Autozone/part store work? What's my next step.
Old Dec 8, 2016 | 09:20 AM
lseguy's Avatar
2005 c230
agreed. Get the diagnostic done, then do the actual repalcement of the parts yourself.
Old Dec 8, 2016 | 10:37 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
As the two gentlemen above stated, put it on a diagnostic system. This is a complicated distributed digital control system. If the relay wasn't locked in the "on" position, you have problems elsewhere.
Fuse and relay in attached snip.
Internet searches can be your friend. Spend a week or two searching for anything and everything about your car and you will end up with a plethora of reference information.
Attached Thumbnails Compressor went out, replaced and car still will not rise-sas-fuse-relay.jpg
Old Dec 14, 2016 | 10:24 AM
Lil754boy's Avatar
E500
My mechanic is booked until 12/19/2016, therefore I am trying to do all I can before that time. I have found the 40 AMP Fuse F61 is not getting any current. Anyone ever had this issue?
Old Dec 14, 2016 | 03:24 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
so...you've replaced your compressor and relay. did you determine if you have a leak anywhere which caused your compressor to stay on?
without star diagnosis nobody here can tell you much. for my situation though, my airmatic computer failed due to broken ecu pin. the pin broke on its own and was never touched prior. it took me 6 months to figure this out as the connector looked perfect and the break was inside the connector.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
