E55 AMG V8 Kompressor 2004 E 55 AMG Type: 5,439 cc (5.439 L; 331.9 cu in) Supercharged V8 Powe
Torque Boost Gauge Set Max / Min Value
Hope someone can help me here Torque Boost Gauge driving me nuts Realtime information Boost Gauge we'll as standard looks like this set to PSI. Can anyone advise me I did set
UNITS TO
Use psi instead of Bar
Don't display psi as in/HG
dont convert negative psi readings to in/Hg
Still looks like this haven't really got crazy flooring in but I'm sure with right Gauge settings this can be better I really tried many things guys.
Nb HP and Torque many times shows no data then data then no data then data everything else works fine trough S6 Edge Elm Bluetooth cheap setup but but appriciated just not easy to figure out the display / gauge settings boost
