E55 AMG Upgrade list questions
2004 Mercedes Benz E55 AMG
Here are my upgrades I got a few questions -
180 mm vrp crank pulley
82mm tb
Needs wings cold air intake
83mm clutch supercharger pulley
Floored fab long tube headers
C63 vorsteiner exhaust
Eurocharged heat exchanger
Bosch 010 pump
Split cooling with return reservoir
One step colder plugs
Upgraded coils
Water injection with a cm10 nozzle
Looped fuel rail
550cc injectors
Ecu tune eurocharged by jerry
Am I good on cooling mods ? If not what should I add?
Also what kind of power should I be putting down with these mods ?
82mm tb
Bosch 010 pump
Upgraded coils
Looped fuel rail
550cc injectors
82mm tb
Bosch 010 pump
Upgraded coils
Looped fuel rail
550cc injectors
82mm tb
Bosch 010 pump
Upgraded coils
Looped fuel rail
550cc injectors
do you have any problems with map sensor cel (82mm tb)?
How much do your IATs raise over ambient? If it's a lot the issue is likely your meth isn't set up correctly.
