Rear main seal blew again!!!
ok so had rear main seal replaced along with pcv valve, intake manifold gaskets, valve cover gaskets. And it just blew again. Any ideas what's going on???
Crissus (01-12-2017)
2013 ML350 Bluetec
Before going into the mechanic with guns blazing, consider the possibility of a defective part. Certainly consider the possibility of other issues causing the blown seal, but if they're willing to make it right then why not let them?
If there was excess crankcase pressure then it would most likely vent out of the oil dipstick tube and not blow the rear main seal out. Sounds like it was an incorrect part that was used and/or it was damaged when it was pressed into the block. Impossible to blow out a new seal that was the correct part and installed properly.
Probably just slapped on a new main seal into the old metal plate. If you do rear main seal you need to change the plate, new seal and let the sealant cure over night, or it can leak.
