rear bearing fail
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
rear bearing fail
How common is the rear bearing to fail? I think it prematurely failed only have 60k miles on my beast. How difficult is it to replace? Where can i find one at a reasonable price? I'm mechanically inclined so I think I can tackle this project since i'm about to work on my rear end. Is there a DIY somewhere. Looked around the forum and Web but no luck for our platform.
well Hotsauce55, originally I thought it was my brakes, so I took the brakes apart and removed caliper as well to rule out brakes. as I spin the hub you hear the grinding like bearings are shot. drive shat seems in tacked so I ruled that out as well.
I believe the seal failed cause there was some rust where the drive shaft slide in the spindle. So anyone have any DIY or a source where I can purchase this?
I think this should be close
Mercedes Benz Workshop Manuals > E 500 4MATIC Wagon (211.283) V8-5.0L (113.969) (2004) > Steering and Suspension > Suspension > Rear Knuckle > Component Information > Service and Repair > AR35.20-P-0115T Remove/Install Wheel Carrier
http://workshop-manuals.com/mercedes...wheel_carrier/
