Help! Valve Cover Service, Now P0505 CEL! [SOLVED]
Old Feb 23, 2017 | 11:55 AM
Rob CL's Avatar
E55 AMG | Buell Lightning XB12
Exclamation Help! Valve Cover Service, Now P0505 CEL! [SOLVED]
So many of us have experienced the joys of replacing the M113 valve cover gaskets and breather sealant. So I thought I'd try to help out by sharing my experience with the pesky P0505: Idle Air Control issue.
Hopefully this will save you some time and frustration in the future, especially if this is your first rodeo.
For the second time, the valve cover breathers started leaking (about 20k mi intervals so far). Add to that, the valve cover gaskets themselves started to leak also. So I figured: It's winter and I'm not driving the car, why not knock a few things out?
The job was simple enough: Gaskets, RTV, wrinkle coat the valve covers, change out spark plugs.
Everything went swimmingly, until I took the car for a joyride.
Well now, this is interesting.
After checking every breather hose, several times, I remembered this little guy was in the way during the tear-down...
Near cylinder #8, I found the problem. Silly me forgot to see where the other end of the aluminum tube goes upon re-assembly.
With the help of my borescope I spotted the problem, an open port on the back of the blower.
Note that there is another nipple on the back of the supercharger near the top half, you can't and shouldn't attempt to re-insert the tube there.
After buttoning everything back up, the AMG is breathing fire once again (via all the correct paths).
Hope this helps!
Old Feb 23, 2017 | 05:36 PM
Dublinoh's Avatar
E63 AMG 2007
Nice post and sure to help someone.
Old Jun 7, 2018 | 02:59 PM
gheorghe's Avatar
E55 AMG
I know this is an older post, thank you for pictures.
I've been battling the P0505 DTC since I bought my car last Novemebr, I checked the pipe you mentioned, even removed it, put my vacuum pump to it while sealing one side to find no leaks in the pipe. Re-inserted it in the supercharger properly, drove it for ~40 miles and my friend P0505 is back
I'm at a loss
Old Jun 7, 2018 | 03:24 PM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
I'm getting ready to do the valve cover gaskets on my 2003 E500 M113 motor.
I've read conflicting information on how much RTV to use and where to apply.
Pelican Parts DIY shows a couple of dollops only at the circular cam areas.
Other write-ups suggest putting a thin bead all along where the gasket runs.
Lastly, I saw another thread where the guy used a generous amount of the stuff to seal.
Thanks for any help.
Old Jun 8, 2018 | 03:35 AM
tw2's Avatar
tw2
I am pretty sure the answer is in here
You need to apply it to the whole breather cover and bolt hole channels. I have not used any on the main gasket for the valve covers.
Old Jun 8, 2018 | 06:58 AM
Thank you tw2.
Old Jun 3, 2020 | 04:21 PM
Mr._Hamilton's Avatar
1999 e430
I know this post is kinda old but this is the closest I’ve come to finding what I’ve been searching for, so I hope someone can help me out.
Does anyone know what that second nipple on the back of the supercharger is for? And, what if anything connects to it?
I took the car apart a few weeks ago and I don’t remember disconnecting anything from this nipple, but I’d hate to put it all back together and have to go back in for a small vacuum line.
any help would be appreciated.
