well this doesn't look like any fun...
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
driving home last night from dinner, heard this weird pop sound and get the infamous red battery light - visit workshop...
lost power steering, but drove it a mile home...
see anything missing? oh - what's that coiled up below? :S
ugh, not a snake...
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/2017_03_03_07_16_59_a058cb7a37bfe5bcee2d47625783110843ca4bb0.jpg)
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/2017_03_03_07_18_26_6336efc3dcf9b04f3332df4c03ca418b8fa3649c.jpg)
ugh, not a snake...
Toadster (03-03-2017)
Pull the belts off the car
Pop the dust cap off the front of the pulley
Unbolt the double idler and replace with new one
Replace belts
done
Replace belts
done
Toadster (03-04-2017)
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
'99 and '05 E55 AMG
The rebuild parts for the supercharger idler pulley (the dual pulley) are:
Dayco 89130 is a direct replacement for the plastic pulley. A Dayco 89012 will also work but requires sanding down one side a couple of millimeters. 90mm O.D., 17mm I.D., 6-rib, 22mm belt, 25-28mm width. The stock pulley is 26mm wide.
Metal pulley bearing is a NSK 6203 ZZC3 bearing or equivalent.
The above will cost you about $27 to rebuild versus $540 for a replacement double pulley.
Elhonaz (03-04-2017)
shardul (03-08-2017)
