E55 Build
Old Mar 5, 2017 | 02:11 PM
AMG_FamilyCar's Avatar
C63 AMG P31
E55 Build
Old Mar 5, 2017 | 04:39 PM
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
I'd make the final drive shorter.
Old Mar 5, 2017 | 04:43 PM
blackbenzz's Avatar
haters crazy
Can you run more than 17psi without going into limp mode? 180 crank pulley in addition to thebsmaller sueprcharger pulley is overkill. I have a modified 90mm weistec supercharger inlet and 90mm BBK tb with threads already for dual meth nozzles if you're interested. I took it off mine because the tuning just wasn't there for drivability
Old Mar 5, 2017 | 05:04 PM
C63 AMG P31
I'm not sure what PSI I'll be running at the moment for the car is getting put back together. For the Supercharger Pulley then I should remain with the 62mm instead of 56.5mm. I will look for that trend for 90mm TB and follow suit, what you mean for drivability?
Old Mar 5, 2017 | 06:02 PM
C63 AMG P31
How would I do that?
Old Mar 6, 2017 | 01:59 AM
blackbenzz's Avatar
haters crazy
I am just running the smaller upper pulley. I think with a 180 lower you will overspin the supercharger way past its max efficiency. I mean it wouldn't drive smoothly sometimes.
Change the differential gear ratio
Old Mar 6, 2017 | 06:41 PM
BC928's Avatar
2006 E55, Various other German and ‘Murican
Who is doing the trans and what is being done?
Old Sep 26, 2017 | 12:26 AM
HumboldtAMG707's Avatar
2003 CL55 AMG
How did your car do with cams and the weistec kit. My tuner and another mechanic told me they create too much vacuum. Just wondering because I really like the lope they make
Old Sep 26, 2017 | 01:30 AM
C63 AMG P31
The car does well I just recommend Anthony Lawshee from Race IQ Performance to do the tune. The loop is amazing and definitely a crowd pleaser too. This November 3rd I’m taking the car to do a TCU n Dyno Tune with Anthony. Without building the bottom end I feel max whp is 600-630whp max before you start to worry about it popping. I run Water Methanol and I LOVE it!! I hope you get that loss boost resolved.
Old Sep 26, 2017 | 01:42 PM
E55amg0220's Avatar
Veteran: Air Force
2003 Mercedes E55 AMG
would love to see some pics of the benzworks e55 headers .... any idea on price and avaliability??
Old Sep 26, 2017 | 02:03 PM
C63 AMG P31
I got the E55 BenzWorks LTH but I had them ceramic coated by Specialized Coatings.
Old Sep 26, 2017 | 02:04 PM
C63 AMG P31
Old Sep 26, 2017 | 02:51 PM
E55amg0220's Avatar
Veteran: Air Force
Those look really good
