Draining coolant
Old Mar 6, 2017 | 02:42 PM
Island_Moose's Avatar
2007 E63 AMG
Draining coolant
The process for draining the radiator (and everything above this drain) is pretty straight forward, but does this also drain all of the coolant out of the engine block? If not, where is the engine block drain?
W211 E63
I've searched the forum to no avail.
Old Mar 6, 2017 | 02:49 PM
BoostedAero's Avatar
2004 E55
W211 E63
I replaced my Radiator and drained all I could. Upon replacement and filling with distilled H20 there was a lot of indication in coloring that there was a large volume of coolant left in the block/IC curcuit.
One would assume this would mean there are pockets that cannot drain in the block. I am unaware of any volume amounts though... Flush it once, drive around for the weekend, flush it again on Sunday and you should be good. That is assuming as well you are trying to flush all your old coolant out and replace it.
