Uneven Panoramic Roof Closing
I have read multiple posts on multiple forums about the panoramic roof. I have tried the reset where you hold the button in four positions for 5-Seconds each. I have reset the fuse in the trunk and am able to close the sunshade that way, but not the sunroof completely. I have removed the rear view mirror and tried manually closing the roof with a 4mm hex, but it will not close completely.
The passenger side will close completely, but the driver side will not seat all the way. This leaves the rear portion of the driver side corner propped up. I have even gone as far as closing it with the button and pushing on the roof, but it still won't close. The problem I am running into now is that it's raining and I am not sure how long I will be able to keep the rain out.
Any help would be greatly appreciated.
Using the big 4mm cranking allen it only actuates the motor gearing manually... if gears are stripped (machine gun sound) it will not grab enough to close all the way... hope that helps
