diff- drive shaft p
Old Mar 27, 2017 | 08:16 PM
khalid janahi's Avatar
W211 E55 / Ws6 Procharger
diff- drive shaft p
funny i drove my car gently and a sound came from the back suddenly the rear diff oil cooler braked and the car was vibrating like something is pulling me from the back i toe the car to my home and had it inspection,r jacked the car
lifted up there was strange sound from the diff is that normal video is attached, some sound in the centre shaft so and i have one bad flex disc so what do you think ?
https://www.youtube.com/watch?v=lUeP...ature=youtu.be
Old Mar 28, 2017 | 08:07 AM
Old Mar 28, 2017 | 09:13 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Judging from the pictures flex disc has gone bad.
Old Mar 28, 2017 | 01:45 PM
BoostedAero's Avatar
2004 E55
^ +1
Also, though your description is very rough to read, it sounds like the rear diff locked up and will need replacing. I would take the diff out, pop the cover off and inspect the gearing while you are under the car replacing both flex discs (replace transmission mount while you are under there...you are going to be right there and it is prob toast too)
I have a feeling the gearing locked up to display the symptoms you are describing
Old Mar 28, 2017 | 01:57 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
What would cause this?
Old Mar 28, 2017 | 02:17 PM
2004 E55
Honestly you got me, I have only known one other high HP e55 with a failed rear diff.
An old buddy I drove his car with a 180mm CP on it and I was sold on the AMG power (reason I ended up with my e55) he sold the car and the new owner called him and said the rear diff failed about 5k miles after the sale...
I get worried bc I now have 132k on my car... his car had the rear diff fail at 136k :-/
***I was not able to get any symptoms from the friend with the old car with failed diff. In the video, listen to that thing, something definitely is a miss though... sounds like a ball-peen hammer tinging off metal :-/***
We maintain race cars not family sedans I am learning
Old Mar 29, 2017 | 03:18 AM
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
Carnage.
Looks like prop shaft and everything attached to it needs inspected at a minimum. And yeah the diff sounds rooted.
I think you can buy those brass bushes the the pinion ends of the prop shaft slide inside? The center hanger bearing and then the guidos and inspect the diff. I wouldnt of thought the brass bushes would get flogged out enough to make that diff rooted tapping noise from the Guido flapping around unless its been like that for a while.
For it to blow the heatsink cover apart that lot must of been really shaking about.
