4000lb Sideways
Rating: Thread Rating: 3 votes, 5.00 average.
Old 05-10-2017, 04:07 PM
  #51
jumph4x's Avatar
W210 DRFT BNZ
Originally Posted by JoeJErnst
Awesome! I'll order one as soon as they're back in stock and start playing around. In the meantime, here's some homework for you. ;-) Figure out the code for the intercooler pump. I assume it's on the CAN bus because you can turn it on and off using STAR. It would be way cool if we could turn that thing on using a button inside the car without having to cut up the factory harness in any way.
I am not going to be doing that, but it's almost definitely doable with CBT if it is doable with Star.
Currently I only have my CBT wired into CANBUS B (interior), to tinker with the pump you would also have to wire it into CANBUS C (chassis/motor). CBT actually supports three buses at the same time, so this is very doable.
A project for the future, for sure.
Old 05-10-2017, 08:05 PM
  #52
jumph4x's Avatar
W210 DRFT BNZ
The steering wheel is off.
Nobody makes hub adapters to I will have to do the FCP Euro Motorsports team did with their C300: hack off the rest of the steering wheel and use the aluminum center as a foundation to build my own spacer.
This guy will have to stick around:
The main harness you see will be cut and terminated (it does not unplug, it is perma-soldered to the ribbon inside of the assembly). The reason this has to remain is two-fold. One is: it is a convenient existing route for the transmission shift buttons, two is this:
The bottom right corner there is (i am guessing) how the car keeps track of the steering angle, be it for ESP or what have you.
In terms of the shifter buttons, these are interesting. Each button has only two contacts (expected), but the complete mini harness for both buttons has only two terminals as well. This wouldn't be so weird because the steering wheel buttons on the front send the data via CANBUS B, however, this is a separate circuit entirely.
The plan now is to try and use factory shift buttons on a Momo Prototipo (already ordered) along with the factory mini-harness. The original plan was to use custom momentary switches on an RJ9-coil cord bypassing the steering column.
And finally, this guy came in for some R&D and test+fit:
it takes apart nicely and will be widened and modified to accommodate two Wilwood reservoirs, so we can preserve the factory ESP/ABS function instead of the usual drifter T-junction for rear brake lines.
That and the rear brakes are massive. We will need the hydraulic volume displacement of a dual setup to do it efficiently.
Old 05-10-2017, 11:29 PM
  #53
jumph4x's Avatar
W210 DRFT BNZ
Took the stupid look-at-me badges off. Nothing like some extra plastic to make a $70K sedan look like a Chinese toy.
Old 05-10-2017, 11:54 PM
  #54
jumph4x's Avatar
W210 DRFT BNZ
Can someone help me out figure out what the pump next the audio amplifier is used for? Behind the trunk trim on the left is the said pump and on the opposite side (on the right) is a large shiny air tank.
The suspension pump is front left, behind the bumper and since the doors in this generation Mercedes aren't pneumatically actuated, I'm at a bit of a loss.
Old 05-11-2017, 01:21 AM
  #55
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
I don't remember seeing a pump on the left side of my trunk. Got any pictures? Pretty sure the silver air tank on the right side is for the airmatic system.
Old 05-11-2017, 01:26 AM
  #56
jumph4x's Avatar
W210 DRFT BNZ
Originally Posted by BoostedAero
https://www.youtube.com/watch?v=EtTI_FY4YnY&t=19s
CAN connections to steering wheel buttons are pre-set and function. You can pair your phone with bluetooth and make calls etc
Pretty sweet for $300 and I am an audiophile. Its a droid so I have torque hooked up and it displays gauges for IAT/RPM/Boost which is nice also and makes logging pretty easy as well and pairs nice data sets to go with Zeitronix =D
I threw in all my old gear from another build
JL 300/4
JL 500/1
JL 12w6 v2 in trunk
Droid HU
That headunit looks like the ticket for me. I'd love to go that route, but help me understand something:
I reviewed the original thread and I looked at eBay listings and I see that my connections don't match the ones found on other W211s. Look at my photo of the back of the headunit again, the only hookup is the three power leads (ground, ACC, VDC) and two fibreoptics IOs.
Am I correct that I will still be able to install this unit, but I will need the 6m cable running to the back of the car where the connectors will be available near the factory amp?
EDIT:
This is what I'm thinking:
Android headunit: http://www.ebay.com/itm/Android-5-1-...BZDC9~&vxp=mtr
Cable that I see available: http://www.ebay.com/itm/Car-Stereo-W...cAAOSwKtVWwDOw
Old 05-11-2017, 05:22 AM
  #57
jumph4x's Avatar
W210 DRFT BNZ
Setup my Arduino development environment here, after struggling with the custom hardware package on Ubuntu, it worked right away on Windows. I guess this will be the one software project I work on in Windows 10. There really is a first time for everything!
It compiles and everything is happy, but the stock program is already using 72% of the program memory. Considering I don't have concrete plans for it yet, this will probably be plenty of room for whatever I end up doing.
This is build 0.7.1, which the official desktop app doesn't even know about yet (it hasn't been re-released since the latest pull request got merged for the Arduino code).
Old 05-11-2017, 05:36 AM
  #58
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
That pump runs all the air bladders in your seats.
jumph4x (05-11-2017)
Old 05-11-2017, 08:24 AM
  #59
BoostedAero's Avatar
2004 E55
Pump in the back left of car encased in foam is the pneumatic pump for the front seat lumbar adjustments etc it fills the air bladders in the seats
Old 05-11-2017, 08:25 AM
  #60
2004 E55
Oooops he got dis^ Thats what I get for not scrolling down all the way lol
Old 05-11-2017, 08:37 AM
  #61
2004 E55
EDIT:
You only need 6m cable if you plan on using the factory amp. You would need to just ditch the wiring on the back of the head unit... its worthless, just zip tie it up out of the way. You need the usual, 12v constant, 12v switched off ciggy, ground. Rest is pretty easy. There is a plug that connects to the speaker connector and has pig tail to go to your aftermarket amp speaker out.
If you use the factory amp get the 6m cable and the factory Fiber Connection box from what I read. I had gear to install so I said screw that and went another way. I suggest you get a used 300/4 or something along the lines of 75w rms/ch. I can only turn the gain about 1/3 of the way up on the amp and then the speakers get to their limit. You will need a small amp to power the factory sub if you want a little knock 150rms is all if could take in my opinion.
I just took a piece of silicone vacuum tubing to connect the fiber circuit off the back of the HU. I could not get anything off the connection on the back of my head unit in ways of power,ground and 12v switched.
Hope that helps. There are about 15 makers of these units, get one with a solid warranty and some decent specs, most use the same android base MCU and RAM may differ 1Gb/2Gb
Hope this helps, hit me up with questions if ya like i dont mind
Old 05-11-2017, 01:00 PM
  #62
JoeJErnst's Avatar
It looks like CANBust Triple is a zombie product. The store is empty and all of the forum posts have gone unanswered for over a year. I'm looking at Carloop.io as an alternative. Do you have any experience with that product?
Old 05-11-2017, 03:44 PM
  #63
jumph4x's Avatar
W210 DRFT BNZ
Nope. Looks perfectly fine though.
Old 05-11-2017, 03:48 PM
  #64
jumph4x's Avatar
W210 DRFT BNZ
Makes sense. I want that 6m cable so that I can place an aftermarket amp where the factory one was.
No way am I using the factory unit.
Old 05-11-2017, 03:52 PM
  #65
JoeJErnst's Avatar
We'll find out 'cause I just ordered one.
Old 05-11-2017, 03:56 PM
  #66
jumph4x's Avatar
W210 DRFT BNZ
In that case, go ahead and join the club over at https://mbworld.org/forums/audio-ele...b-hacking.html
Old 05-11-2017, 08:46 PM
  #67
jumph4x's Avatar
W210 DRFT BNZ
Thanks! Looks like I should put it back where I found it.
Old 05-12-2017, 11:18 PM
  #68
jumph4x's Avatar
W210 DRFT BNZ
Got the center console out, got the gear selector out. Pics soon.
The Keyless-Go button will be easy to rewire, the wires and connector are easy to access. Same for the linkage to detect gear changes at the shifter post. I don't think I will need to tap into these, but if anyone does - it's pretty straight forward.
Shifter will stay off while I cut the carpet and plan some plumbing routing.
Old 05-14-2017, 01:11 AM
  #69
DARTH MAGNUS's Avatar
2014 Subaru WRX
Subbed
Old 05-15-2017, 08:46 PM
  #70
jumph4x's Avatar
W210 DRFT BNZ
Looks like I have the HK setup with a million speakers in this car, took some photos for eBay vendors to make sure I'm buying the right stuff for this car.
The folklore and hilarity of the factory amp placement did not disappoint. I was laughing while desperately trying to under the last bolt, it's pretty extreme.
When getting the shifter assembly out, there will be mechanical linkage at the bottom of it with a circlip holding it together. When the entire unit is out, note that the black and white plastic assembly pieces are glued together.
If you take a sharp blade and gently but firmly wedge the blade and inflect it, the pieces will eventually separate cleanly:
Here you can see the Keyless Go wire running through the inside of the shifter rod and the connector that is very simply to tap into, great news:
Secured to the top of the white cover is the tip-sensor for changing gears. If you didn't have factory buttons but wanted to retrofit, what I would recommend is tapping into these guys, running a wire to the steering wheel dash and then making a race-style RJ9 coil cord to the wheel. Would look awkward on the factory wheels, but I bet it would look great with an aftermarket wheel.
The assembly will stay out while I jack the car back up and start measuring and planning plumbing of brake line.
Old 05-16-2017, 12:18 AM
  #71
jumph4x's Avatar
W210 DRFT BNZ
So, since I have the Harman Kardon speakers, I would like to keep the subwoofer and the two rear parcel speakers.
Old 05-16-2017, 04:50 AM
  #72
jumph4x's Avatar
W210 DRFT BNZ
Ordered the Android headunit and a 4 channel Pioneer amp for the trunk.
Old 05-16-2017, 07:27 AM
  #73
Dublinoh's Avatar
E63 AMG 2007
Appreciate the pictures. Do you have the power trunk option? If so, while you're in there, check the wires for insulation breaks and fraying copper, common problem. Cheers
Old 05-16-2017, 12:51 PM
  #74
jumph4x's Avatar
W210 DRFT BNZ
Cheers. I do have the power trunk, mind linking me to a thread or posting a photo of where and what to look for?
Everything I could see without close examination looked good.
Old 05-16-2017, 01:20 PM
  #75
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Which head unit did you end up going with?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: 4000lb Sideways
