Fixing split open sun visors.
Old May 21, 2017 | 11:39 AM
Blade Canyon's Avatar
2012 E63 AMG
If your sun visors have opened up at the seams, here's what fixed mine.
Just squirt in Elmer's glue, then clamp it shut over night. To prevent the clamps from making permanent marks on the visor, I use those free paint stir sticks you can get at any hardware store. So squirt in the glue, put the stir sticks along the top and bottom, then add clamps.
It's only been a few days, but it feels pretty solid.
Old May 21, 2017 | 02:18 PM
The Fly 1's Avatar
E-55,IS-250
Thanks for the write up!!
I'm having that problem right now
Old May 21, 2017 | 02:51 PM
2012 E63 AMG
There's probably a better glue to use than Elmer's, but that's what we had in the house.
Old May 21, 2017 | 03:25 PM
AmgSeahawker's Avatar
08 clk63, 06 E55, 05 c55, 14 ml350, 98 pathfinder. Have owned cl55, s55, cls55, c230, cl500, cls500
Mine are split and stiff. Does this help with them being stiff also?
Old May 21, 2017 | 04:37 PM
2012 E63 AMG
No, it doesn't help with the stiffness. I suspect the stiffness is the same reason they split open, because we are overtorqing them trying to move them around.
I've never had any car with sun visors so messed up.
Old May 21, 2017 | 08:33 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
lol, Elmers? You should have gone to the store and picked up something else.
Old May 21, 2017 | 08:35 PM
2012 E63 AMG
That would have been just another reason to put it off. If this doesn't work in the long run, I'll try something different.
What did you use when you fixed your visors?
Old May 21, 2017 | 08:38 PM
HeissRod's Avatar
I have one starting to separate, but haven't looked into fixing it yet. Someone mentioned on Facebook a few months ago what they used for glue, but I never saved it and don't remember. Crap.
The paint stick under the clamps is a pretty good idea, though.
Old May 21, 2017 | 09:41 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Contact cement.
Separate the two surfaces, mask where you don't want the contact cement to stay, carefully swab the contact cement on the two surfaces you want to join, let the cement dry for at least 15 minutes (until the gloss is gone and the surface no longer feels sticky), then squeeze the two pieces into one. Shouldn't be any need to clamp, but if so then the paint sticks will be handy.
