Help with torque app boost readings
Old May 25, 2017 | 02:48 PM
KillaAMG55's Avatar
E55 amg
Hey whats up fellas. Anyone using the torque app have issues with reading boost pressure. At idle it reads -26 and when i do a 3rd gear pull it only reads -5!! WTH! IT seems to pull good i assume. I just got my car. 05 e55 stock. Is it possible supercharger clutch is not engaging or torque app is not set up right. IAT was 85 deg.
Old May 25, 2017 | 08:58 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Not sure if the plug-in to the app has anything to do with it or not, but I'm seeing something like 19 psi max when I'm putting my foot into the CDI... Torque Pro and a cheap ELM27 blutooth adapter.
I know, not an AMG but I'm just pointing out that the app seems to work well.
Your butt dyno would tell you if the supercharger wasn't engaging, wouldn't it? Is it possible your boost pressure sensor has issues?
What unit is the app set up to display? kPA? Bars? PSI? A screenshot might be worth posting up.
Old May 25, 2017 | 11:09 PM
BoostedAero's Avatar
2004 E55
Go to torque main page, edit your vehicle settings or create a profile with info
Similar to the suggestion on FB thread change your atmospheric boost setting. It should be 0 unless at an extremely high or low elevation.
I am in Charlotte NC 751' above sea level and my boost reading is normal for my mods and I have it set to 0
185CP/LTH/Meth PreSC+PostIC = 14-14.5psi in 3rd-4th
Check Settings and try again please See the red tick mark that indicates max reading achieved 6500rpms / 14-14.5psi/Max IAT 120*F
Old May 25, 2017 | 11:27 PM
KillaAMG55's Avatar
E55 amg
Smile
Thanks for the help boosted!!! It works now
Old May 31, 2017 | 02:34 AM
elf's Avatar
elf
2004 Mercedes AMG E55
KillaAmgE55: what did you change to get torque to reading proper boost and air fuel ratio? I just ordered a very nice wifi obd2 reader and have a nexus 7 2013 32gb tablet which I have torque pro installed but waiting on the nice obd2 wifi adapter to come any day. I also have DashCmd app on my iPhone as well that I plan on trying out and comapring the two.
Old May 31, 2017 | 02:39 AM
elf's Avatar
elf
I am in Charlotte NC 751' above sea level and myboostg is normal for my mods and I have it set to 0
booted: I just installed torque pro on nexus tablet and made a profile for my 04 e55, is torque pro accurate when it comes to boost readings and air fuel ratio and logging?
Old Nov 18, 2017 | 03:05 PM
ta72's Avatar
2006 CLS55
Im very curious to know too. I have 77mm pulley with belt kit and at wot, it reads 11.4 psi boost. Not sure if this is normal with this set up.
Old Nov 18, 2017 | 04:42 PM
oneslow55's Avatar
E55 amg
Fyi guys less gauges opened increases the response of the ob2 reading .
I only keep boost and iat on for daily and timing ,boost and intake for open large pulls for big pulls.
Ambient,weather,elevation ,gear and iat will set your final boost reading.
I'm at 5 feet above and my da at times is -1300 so imagine the boost i get at times.
