Replacing Motor Mounts
2004 E55 AMG, 2005 E55 AMG (Sold)
im trying to replace my mount & trans mounts. I have long tube headers and the top bolt of the motor mounts is in direct contact with the headers.
I don't see how I can get the bolt out without removing the headers
any ideas? has anyone with LT headers changed there mounts themselves without removing the headers?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
if the header is touching the mount bolt then that's probably the reason the mount went bad as it got too hot -- need a heat shield and more clearance or it will just happen again -- just sayin --
as to your question, if you can't get a wrench on it, I think there is a specialty merc motor mount wrench or you can cut it out with a torch and probably catch car on fire
or remove the header -- bad design or bad install ?
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
E55 w/ goods, Z32 Project underway
i read your DIY post , some good pointers in there.. i can reach the top bolt with my hand from top of motor or from under the car, my issue is that the i can not get a socket onto to the bolt because of the header
this might be what i need to do then i can move the motor up and raise the headers enough to access the bolt .
i can reach 3 of the bolts easily, but the 4th bolt on the top rear looks very hard to reach
What headers do you have on the car I am curious...
I will go through this shorty once I get finished rebuilding my trans
Making a neat pile of info for those reading
https://mbworld.org/forums/w211-amg/...installed.html
they're custom headers , similar to arh
finally finished this job with my bud over the weekend. PITA . took about 3 hours.
did not touch sway bar.
passenger side was straight-forward. unbolted mount bracket.
dropped steering rack . pushed engine up, pulled full assembly out. installed new mount to bracket with top bolt then put full assembly back in . drivers side was a ***** . mount is attached to ac compressor , couldn't remove mounting bracket from car but disconnected all bolts, removed tension off belt and moved engine up enough to have room to remove top bolt , removed mount only through passenger side & put in new mount
night & day difference with vibrations in the cabin
i do not want to do this again anytime soon.. i had to read a post in an old about strapping down engine to keep strain off mounts ..i will definitely look into this . i did see a cross bar on VRPs site
2005 E55 amg
Good for you. My car is currently at the dealership right now, getting the fuel tank and pump replaced under the warranty. I was told that I need the engine mount replaced, and will cost me about $2,200 to replace it, and another $2,300 to fix the rear main seal. LOl. Do they really cost that much to fix?
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
shop manual says 6.5 hrs to change all 3 mounts . lets just assume a ridiculous labor rate of $200 /hr ..that comes out to $1300 ..total cost of parts at full MSRP direct from mercedes is $361 ...so a grand total of $1,661 ..this stealership is
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Headers or not, exhaust needs to be moved for ease of mounts removal and replacement. All 211 cars are like this.
if I had stock headers, i can't imagine this whole job would've taken more than an hour. the vast majority of time was spent on extra work to access the top bolt due to the design & position of my headers
