How will IAT's be affected with EC mid length headers?
05 E55, 98 CLK320
Current mods: 180mm cp, EC tune, green filters, 010, purple ice and MB fluid in the coolant tank. Split cooling kit should be coming in bought it from a board member, no bigger intercooler yet
No cats, no res, and I'm getting the mids installed next week with an x pipe.
Currently, if I really gun the car in the heat I can get up to 110mph on the highway but IAT will hop up to 180ish deg. No good. What can I realistically expect out of the headers?
I'm thinking about replacing my 180 (ASP? Or ACP? Not sure what brand this thing even is) with something newer and smaller, the idea is to get the pulley squared away so I know it's new and won't break on me, and to install a BWK without stressing the old one too much. Also, I'm not too interested in all this power, I would assume a 170 would be enough for my needs. The car is stupid fast as it is.
Thoughts, comments concerns?
METH will quench that beasts thirst. I would personally get a Snow Kit add a devils own 90* nozzle holder with a DO10 nozzle then get that installed on the flat pad just past the Intercooler.
Your install and kit will cost less than $1k to get done total... thats taking into account about $500 for the install
You are going to spend about that on a used pulley once installed or you will be about $1350-$1500 for a new one...
Headers will not cool you down enough to justify the cost either $650 + another $5-700 to install
Keep your power level, use the windshield reservoir as meth tank and just mix distilled water and Heet (mostly meth) from Walmart. It costs about $3.xx for both. Keep a spare gallon/1 bottle in the trunk in case you need to fill up.
MACEDON (06-01-2017)
05 E55, 98 CLK320
https://mbworld.org/forums/engine-pe...0mm-700-a.html
my pulley looks a lot like this ASP pulley, it has what looks to me like a crack, or a ridge, I can't tell just by looking at it if the pulley is okay nor do I know how old it is. It seems like a very expensive part imho so I guess there's no sense in getting rid of it.
So because of that I don't know if I should replace it at all.
I was looking for a more passive solution for cooling, so that I get the benefit even when I'm not driving the car very hard, the key goal here being to extend the life of the engine by keeping it a bit cooler.
05 E55, 98 CLK320
btw any visual indicators of the shape my pulley is in? Are you supposed to replace the crank pulley as part of preventative maintenance?? I've seen a few instances where people's pulleys snap, not sure if that's custom to the stock one...
Whoops, thought you had an upgraded Heat exchanger...![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
I would still do Meth, you will see more of a difference in that single mod then with it than any other cooling mod
If you plan on going killer chiller down the road then the heat exchanger will be a moot point as it comes out
Things to chew on I guess
2005 E55 amg
If possible, stay away from split cooling kit. Waste of time and money. Never worked for me. No changes seen in my ET/trap speed. Save your money and go for the trunk tank. Gained ~3mph trap speed, and was consistent too.
HeissRod (06-04-2017)
Trunk tank or engine bay tank with killer chiller. With meth you will need to play with nozzle size and meth mixture as every car is diff. These giant nozzles and too much meth equals rich afr and slower cars
05 E55, 98 CLK320
I wonder if the superflo is a worthy upgrade over the 010, if I do this progression: superflo and hxc, then trunk tank, then KC I think I might find exactly what fits my load by eliminating them through method of increasing cost and difficulty of installation.
I amn't planning on drag racing heck even doing b2b pulls on the street all that much really
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
05 E55, 98 CLK320
Yea not sure it will make a difference in a pull on a 1/4 mile run, however in my testing I found the recovery time to be quicker, so in essence its well worth the little cost of the install, I didn't pay USD150 though for the kit, that's just nuts. What I would like now and checking into is replacing the little bmw reservoir tank with something more substantial to increase the amount of coolant and see the difference that makes. ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
