good deal on Mobil1
Walmart also has a 5qt jug for $22.88, making the price per qt nearly identical ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
https://www.walmart.com/search/?query=0w-40&cat_id=0
E55 w/ goods, Z32 Project underway
I have no idea what language that was, so I assume you're agreeing with me
05 E55, 98 CLK320
So I will do a few shorter term "flushes" as they get saturated with gunk, let the detergents in the oil do it's job- then I'll go to "premium oil" which again means nothing if you just change out the mobil 1 at shorter intervals.
I'm basically looking to change the stuff ahead of time to churn some cleaning benefit out of it. I can explain it further but it makes sense in my head.
05 E55, 98 CLK320
I poured the new oil in and planned to change it again at 2k, in the mean time i ran 2 tank fulls of techron and it changed up the car quite a bit... it responds a lot better now so something is telling me there might have been some degree of neglect going on.
As a preventative measure I'll do my next oil change when the mobil one arrives, drive that oil for 3k or 4k, not sure, then I will resume doing 5k changes but I will switch over to Liqui 5w40 suitable for 5w40. Chances are I could stretch the oil a couple thousand more, no doubt, and it is better for the environment... but I'm a stubborn inbred.
Received 1,495 Likes
You guys just missed one. It was from April to the end of May. They usually have one in the fall too, typically from September to the end of October.
I still have lots of Castrol 0w40 from the Autozone clearance last year, $2 a quart, no rebate. That typically doesn't start til December though.
