w211 amg A.C. problems! Help!
Old Jun 12, 2017 | 08:49 PM
jeffsmith09's Avatar
2003 E55 AMG
Exclamation w211 amg A.C. problems! Help!
I have a 2003 E55 AMG which just had a new A.C. compressor put in. The a.c. blew cold air for a day and now warm. I seen the videos of the hidden menu on the temperature control unit with the values and can't remember if I changed any. Can anyone post what theirs are set at?? It's 0 through 99 on the left and the other side displays different temps. Some you can adjust and others you can't. They say not to change any. Oops
Old Jun 13, 2017 | 01:01 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
I'd take it back and have them fix it if it only worked for one day. That's not acceptable.
Old Jun 13, 2017 | 06:28 PM
2003 E55 AMG
Not sure what it's running at. How would I find out? I called aamco and it's going back.
Old Jun 15, 2017 | 05:59 PM
2003 E55 AMG
Exclamation UPDATE!
Aamco said something about a O ring missing, damaged whatever but couldn't find one so had to order one from MB. Covered under warranty since they just put the AC compressor in last week thank God.
Old Jun 16, 2017 | 05:02 PM
Toadster's Avatar
2005 E55 AMG
could be the low pressure hose - over time the hose loses strength and collapses on itself making it warm... check it out
Old Jun 18, 2017 | 01:21 PM
BoostedAero's Avatar
2004 E55
Closing loop
Low Pressure Hose info
https://mbworld.org/forums/w211-amg/...-replaced.html
Old Jul 6, 2017 | 09:08 PM
2003 E55 AMG
A.c. works fine now. They forgot to put in the O-ring..
