E55 AMG power loss and strange working
P 2003 Secondary air injection system (bank 1)
P202E Throttle control valve
P20D4 Load limit is active
What can it be?
Car also one time stoped working,i need to put in gearbox in P and start it again...
Can that fault be related with bad wireing or problem with ecu because i heard MB have problem with that on petrol engines...
1. "mercedes P2003 error code" You will find numerous posts. Most likely a valve failing to actuate on Bank 1 (passenger side in a left-hand drive car). Should be one valve on each side; one failed.
2. Also search on:
"engine 113 intake manifold connecting diagram" and search the *images* (not "all"). The second one is of a W210 engine vacuum diagram showing how to troubleshoot the previous code. This is not an exact match for your W211 but is close.
3. "mercedes P0202E error code" More posts. Throttle valve actuator (M16/6) located on the throttle body on the engine. This throttle valve actuator is listed as M16/1 on the internet search image found via number 2 above.
4. Throttle potentiometer fault you need to provide the actual code. Is it the potentiometer on the throttle body actuator (M16/6) or is it the accelerator pedal located in the driver's compartment? Either one use troubleshooting techniques to confirm wire harness and connectors are good; if so, plan on replacing the actuator and/or the accelerator pedal.
Good luck.
I go see faults again and i got
P2032 Throttle potentiometer (i got that before)
P20DD Pedal value sensor path 1 short circuit
P2027 EGR vacuum modulator
I got Secondary air fault before and i turns out Secondary air pump wasnt working,i fix that...
What bothers me to is that car on cold start raise idle too much and it takes a minute to goes to normal,after fixing secondary air its faster but still i dont know why is it working like that...
