OEM Wheel Clearance Question
2007 E63
Good afternoon all. I'm in a bit of a pickle and I need some advice. Long story short, I cracked a wheel six hours from home and there is a local salvage yard with a few Mercedes but I need to know if any non AMG wheels will clear the rear brakes. The vehicle is a E63. Any help is greatly appreciated!
2007 E63
Thank you so much for the response. I figured the rear did not need as much space as the front but I just needed a second opinion since they are bigger than a normal W211. If I'm lucky there is a set of monoblocks laying around..
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Maybe search for threads on drag setups as well since those guys will generally be running a smaller rear wheel. Might give you a better idea on what will clear.
2007 E63
I ended up pulling a 17" rear wheel from a 350 wagon. Mounted with plenty of clearance. Hopefully it did not harm the diff too much with the slight difference in rolling diameter haha. A 275/30-19 on one side and a 245/45-17 on the other for 400 miles. Perhaps I will have them add the rear end service when I take it in for the 100K service.
