AC blows cold but low volume
Old Aug 30, 2017 | 02:27 AM
daveck2's Avatar
w211 2003 E500 in Pewter Silver Metalic
I have a 2003 E500 and when I run the ac, the fan blows at the various settings but the volume of air coming from the vents is quite low. I run it full blast and even run it on recirculate but it can't cool the car down.
AC is charged up and no codes. I even tried replacing the A/C resistor under the dash, twice, but no help. One odd thing will happen, after running it for a while, the passenger side windshield will condensate on the inside near the defrost vent in the top of the dash. Could I have a duct off, or are my deflectors not directing the air correctly? Anyone else have this problem?
Thanks in advance for your assistance.
Dave
San Antonio TX
Old Aug 30, 2017 | 09:33 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Sounds like your blower motor regulator.
Old Aug 30, 2017 | 10:28 PM
daveck2's Avatar
Thanks for the reply. I thought that too, but when I crank up the fan to max, it sounds like it's blowing hard, it just seems like the air isn't getting to the vents, like it's blocked. Could it be like an actuator or motor that works the blend door on the a/c box maybe?
I'm kinda hoping my other gremlins keep the car parked until the hot TX weather goes away around Christmas.
Old Aug 31, 2017 | 02:28 PM
skylinrcr01's Avatar
2004 E55, Triumph Speed Triple
You check the cabin filters? Some W211s have 3, 2 in the dash, and one under the hood.
