Strange and dangerous problem
Outside temp was 48* and thats the coldest it has been since I did some inter cooler work,more boost,15 psi "normal reading", and new tune. Got on it hard and wound it up good to see what the IAT was going to be after the inter cooler work and car lost power all of a sudden. AFR showed 19.1
Was at 10.5 then instantly shot to 19.1...melt down AFR for sure !!! and lost power of course. Tried it again real quick and same thing. So this is what I do know. IAT was at it's lowest 80* so my work payed off.
Fuel pressure was at 75 and holding and the gauge did register vacuum in the parking lot at work so thinking MAP sensor is good, but....could it be possible the boost hit the limp mode threshold ? That's the only thing I was not watching and I do not know what limp mode would do in an over boost condition. Long story short now I can not duplicate the problem and it's back to normal but it is also 80* again outside.
This is a sure fire way to blow an engine and glad I have a real time wide band in it. Any ideas ??
Gary, sorry to hear about this... that is scarier than when I was running on 1 pump due to the adapter cable NOT being used by the dealer during warranty recall of tank/pumps/sender
When I was running w/o adapter cable I would jump into 11.9/12.2 around 3500-3800 then it would just climb into the low 13.1/13.3 range toward 5500 plus and I would have to just let off so I didn't wet myself with fear
I took it back to them they added the cable now I am running rich and just need a retune
On your car, I would think for sure you had a voltage hiccup/fuel supply hiccup. How many miles/years are on the pumps? How does the relay socket look?
Is there a chance you may have sucked something in through the pump pickup and the injector(s) got semi-clogged with debris and then it blew it out?
I would probably run techron/seafoam through your car (2x 8 gallon tanks back to back.)
Inspect wiring loom at fuel relay and pin-out on fuel hat for over voltage signs. You may have a pump taking a crap or high resistance which would need investigating further.
Honestly, temp differential can cause havoc on electrical signal transmission on aging oxidized connections
BBirdwell had a good write up on fuel relay maintenance with some conductive paste:
https://mbworld.org/forums/w211-amg/...intenance.html
It seems worth cleaning all connections and applying the paste for assurance of seamless voltage transmission on these cars with their age.
I just dealt with another issue that was hard to diagnose as no failure showed up in STAR. A dying but not dead wiper motor that was causing a voltage drop while running that would drop the car into 11.1v then back up to 13.9v...causing symptoms similar in feeling to the mechanical bull I rode a few times after too many drinks at a few bars in college :-/ Unplug the wiper motor symptom disappeared
I learned how intricate, intertwined and fragile the electrical systems are on these cars.
Post an update on what you are finding... I am certainly curious
I will pop in another MAP sensor and keep an eye on the boost. Maybe tomorrow since it will be cold in the morning I will throw ice in the cooler tank to really exaggerate things and see what does. I have raced it in this configuration all year but.. its never been this cold. I would be hard pressed to see more than 16lbs of boost and that would be 1 lb over normal. I will keep you posted!
Are you thinking of something else ??
My bad for not reading your reply a little better. My clamp was set to high and was pushing into the limp mode zone so had to set it much lower to get around the issue.
Did you just literally cut the map. Sensor wires and put the map clamp inline?
