Lowbeams aiming down...?
I've searched all over and it seems when the motor fails, a common sign is that it aims up... but mine is aiming down. Thanks!
https://mbworld.org/forums/e-class-w...djustment.html
You can see if this is the case for you by wiggling the projector unit from behind. If the lense wobbles around without resistance, it's probably the case. It's stayed in place since.
