Supercharger Chirp Fix!
Old Jul 31, 2015 | 12:03 PM
jmb614's Avatar
E55 AMG
Considering this post was created in 2004 I would be amazed if the OP returned to answer your question.
Old Jul 31, 2015 | 12:53 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Based on the description given by the OP, I think it is this product:
https://www.bgprod.com/catalog/brake.../#bg-product-7
Their website has a "find a shop" feature where you can put in your zipcode.
Old Jul 31, 2015 | 12:58 PM
Denroll's Avatar
'06 E55
Originally Posted by hotgreek
I can't find this Stop Squeal product I benn to 3 parts tore no one has it ? Any ideas where can i get it from ?
Thank you
There's a store locator on their site:
https://www.bgprod.com/catalog/brakes/bg-stop-squeal/
Old Nov 14, 2016 | 11:26 PM
kingdolt's Avatar
04 Clk55, 99c280, 92 300e,
Supercharger fix
Originally Posted by TexE55AMG
There is no downside to this fix (no slippage etc.). The fix lasts approx. 2,500 - 5,000 miles before reapplication is needed. One tech I talked to said that the mileage interval can be extended if you take off the front clutch plate to ensure a full and even application of the stop squeal.
One other tech had mentioned a long term fix was going to be tested. They are going to experiment with having the clutch plates impregnated with teflon.
Please note the electromagnetic clutch on the supercharger has a very high clamp force. The graphite does NOT cause slippage of the supercharger. It simply acts as a buffer that prevents raw metal to metal squeal upon engagement.
I know that Mercedes does not have a problem with this fix.
It will not void your warranty.
I have a fix for you. I worked for MB go 13 years and we found if you take a shim out of the clutch chirp goes away a lot longer. You lift engine up just a little and then zip off but on front of pully. Then take apart theclutch and there will be like 3 to 4 shims. Usually 2 different sizes. Take one of the thinnest out and put back together if it still not perfect then repeat and take larger one out and reinstall thinner one.
