Supercharger how does it engage?
Making a fix pulley
Look at the below video and it explains.
A static Electromagnetic ring (locked onto the SC body) magnetizes the Steel ring clutch which runs around it after the ECU has energized that magnet ring. Then that Electromagnetic ring pulls the pulley against it. that magnetized clutch ring. The pulley is driven by a belt going around the Water pump and the Crank Shaft. The ECU energizes the Electromagnetic ring after the engine reaches between 2000 and 3000 RMP so the boosting starts. at lower RMP the engine is virtually idling so it does not need boosting.
https://www.youtube.com/watch?v=d_kPn9gb4s8&t=202s
