OVER BOOST LIMP MODE
It was very strange and has never done it again but temps are much warmer right now.
I'm amusing the car fell on it's face and you saw the 19afr? You might be right, hit just right conditions to creep you over 17psi and cut fuel.
A map clamp is hooked up in series with the MAP sensor output, and limits the voltage the MAP sensor can feed to the ECU, in effect limiting the total boost the ECU can actually see to a value that you can usually adjust with a rheostat on the clamp.
You are effectively just putting a cap on the pressure the ECU can see, even though actual pressure may go above it.
If you are just barley teetering the point of fuel cut, if you haven't already I would grab a set of long tube headers which should give you a nice power bump and drop that pressure a pound or two haha
It has only done this twice...one time I must have lifted off the throttle just a tad and it ran lean in the summer but this time it did it twice back to back. The first time under heavy boost in 48 degree weather with ice in the tank and than back to back after that lean again but did not cycle key after the first time. also did not notice boost...was not looking at that just the AFR. I have since installed a fail safe that shuts the compressor off after 12.1 AFR so don't have to worry about popping the engine now.
