Airmatic stuck UP/Raised position?
![Post](https://mbworld.org/forums/images/icons/icon1.gif)
Hello all, the airmatic struts are completely new on this car, thankfully all four have been replaced with AMG struts. The compressor relay has been replaced and now the compressor turns on and off properly..
I cannot get the car to lower down into sport mode(s)
Its stuck in Comfort mode, however the dampening mode selector lights up and the suspension still becomes very stiff when I select sport mode.. but the ride height remains the same.
I can hear the air release valve release air from time to time, and the compressor does turn on properly.
I unplugged the battery overnight and it caused the comfort mode to soften up, but again the ride height wont budge.
Some people say its just a broken wire going into the pump? I'll attach a schematic for reference, if you have any ideas I would appreciate it. Maybe there are some fuses/sensors I should be checking? The parts numbers are all listed in the PDF
