Airtex E8572M Fuel Pump Module Assembly
Sorry for the out of focus This is the A 211
This is the Airtex
The ones that should fit with the Airtex are:
A211 470 24 94
A211 470 51 94
The A211 470 64 94 filter is used with the A211 470 00 00 fuel pumps. These use the fuel line connectors that fit over the pumps' fittings.
Also ordered one of these
Also ordered one of these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
That said those plastic lines are very hard and not easily seperated from the fittings like rubber hose would be....
And the lines might even be different sizes where the slip into the fitting.
I did this on a w211 e350 once. It was not fun to do.
Agrh! Thanks that what happens when you read what you want, not whats written
