Another victim of the M156 headbolt issue...
SPONSOR
2007 Mercedes E63 AMG
i'd recommend swapping in a used motor.
secondly...your write off amount will be negligible and you're better off selling the car as is. your car is a clean wagon and honestly you could swap in a used motor and sell the car. while the motor is out you can proceed with basic preventive maintenance and reseal all oil pans, oil thermostat o-ring, etc.
your car would still sell for a nice dollar figure with a used motor. i too am like you and have done the very most preventive maintenance. this past service i sucked it up and went with a head bolt replacement for safe measure. sorry to hear that you are dealing with this but we all know beforehand Mercedes/AMG really doesn't care about the head bolt issue. It's like with certain model GM's trucks...their transmissions fail around 80-100k and since they're out of warranty you're out of luck. with the margin of failure so low prior to warranty end, its really a tough luck to the consumer.
Bahnstormer (11-13-2017)
Received 1,491 Likes
I'm pretty sure they did as the problem was fixed in 2011. Just amazing that the problem lasted so long before new parts came out, but I guess it probably took a few years for the problem to appear.
SPONSOR
Look at the Audi B6-B7 S4 engines...they grenade between 80-140k because their cam chain adjusters run down to the metal, their tensioners fail entirely, or their cam phase adjusters bolts sheer straight off. Audi hasn't recalled that..."sorry, you're out of warranty" also they don't have updated parts for any of these pieces.
The updated M156/M159 bolts are around 480-500 a set vs 1200 for the Weistec units. Also APR won't sell you these bolts directly. The only way to order these is to order a batch of these bolts with exact specifications and they come out to 800 a set I believe. Not sure the quantity that will need to be ordered though.
The updated bolts have survived 800bhp without issue thus far on a few members supercharged engines.
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
I talked to my mechanic and he said updated head bolts are available from MB. He said the new head bolts were $240 for a complete set. Not sure if that's his price or retail.
Former Vendor of MBWorld
Both Updated and ARP are good options, if youve already snapped a bolt go with the OEM as you will be removing the heads. if you plan on doing a one at a time swap the studs would be your best option
#32
#33
SPONSOR
156-016-07-69
Cylinder Head Bolt
$8.40
20
$168.00
is what i paid for from Genuine Mercedes Parts website prior to shipping. my local dealer charges double for everything. hence the previous price i mentioned.
Cylinder Head Bolt
$8.40
20
$168.00
#35
Im sorry man that you had to go through this, but did you realize this car has this problem???? Its like a m3 v8, if u get it, you do a rod bearing maintenance because you don't wanna pop the motor. Everyone knows that the headbolts are horrible on the m156. Like all these guys are talking on this chat are just beating around the bush I'm honest. If you replaced them you wouldn't of had this issue. Tomorrow if i were to buy a c63 prelift, i would take it straight to a dealership and do the headbolts because now they have revised ones that won't leak coolant. Its just sad that you weren't informed or choose to not do it. MB are crooks they should have covered this but one day they will because it took w211 owners many years to get the fuel sender units and fuel pumps replaced after leaks.
#37
It's nice to say everyone should know about it and fix it preemptively, I would, but some people just buy a nice car to drive it and have fun. They aren't on forums and don't have this semi-technical knowledge and certainly not the skills for a DIY.
#38
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Driving a high end sport car takes money, you might get lucky and never need to replace a transmission or engine but you should do what needs to be done to prevent it. The ZF tranny in my RS6 is the weak link and it’s keot me from tuning the car or even servicing it because it has 90k on it and I can’t tell if it was ever done.
Im planning on doing the headbolts, even though the E63 only has 30k miles I don’t want to fork out more in the end if they fail. Amazing to me MB got away with this one. I can’t do much now, the car is out of warranty now.
Shame me to see the wagon go to auction with a bad engine. Would be a fun car.
#40
Even with a bad engine that car is still worth a pretty decent amount of money.
#41
Really sorry for what happened to you and really scary as I also have a E63 Wagon that also has almost 100k miles ...
#43
SPONSOR
haha...if you take out the faults of the M156...its a pretty amazing engine. I think it won some awards for best V8 engine. i initially was on the search for a CLS55 but ended up with an E63...after owning this engine I love it every day.
https://mbworld.org/forums/w211-amg/...ds-2010-a.html
Looks like the 63 (M156 and M159) have done it again....
They won this award a couple of years ago and now this year again ![drive](https://mbworld.org/forums/images/smilies/driving.gif)
[SIZE="+1"]AMG V8 wins "International Engine of the Year Awards 2010": Mercedes-AMG builds the best sports engine[/SIZE]
![](http://img411.imageshack.us/img411/9707/72002013050484800270009.jpg)
"Bearing the internal designation M 156, the AMG 6.3-litre V8 engine with its displacement of 6208 cubic centimetres produces between 336 kW (457 hp) and 386 kW (525 hp), develops up to 630 Nm of torque and features in various AMG models, including the C 63 AMG, the E 63 AMG and the SL 63 AMG. The basis for the agile power delivery is the consistent technology transfer from motorsport, which has been an inseparable part of the company philosophy at Mercedes-AMG for over four decades. The verdict of juror Jason Cammisa from Automobile Magazine (USA): "The absolute epitome of a German hot rod V8 engine!" Carl Cunanan, editor of C! Magazine (USA): For its fantastic engine sound alone it deserved first place!""
"The great potential of the award-winning AMG V8 is also reflected in its character-packed, powerful evolution: the engine – dubbed the M 159 – for the SLS AMG super sports car is based on the M 156; in the gullwing the AMG high-revving naturally aspirated engine develops 420 kW (571 hp) and delivers maximum torque of 650 Nm. Another outstanding vehicle is the C 63 AMG with Performance Package Plus and maximum output of 358 kW (487 hp). The overhauled features inside the engine are responsible for the increase in output: the forged pistons adopted from the SLS AMG together with new connecting rods and a lightweight crankshaft make the engine three kilograms lighter. The reduced inertia enhances the agility of the eight-cylinder unit, which offers even more exhilarating responsiveness."
http://www.germancarforum.com/pit-ge...ds-2010-a.html
#44
not to dismiss the OP's issue, isnt the newer biturbo e63 based on the m113k and the mcclaren's (i cant remember where i heard that so maybe i am off base) ? it seems like any motors that have forced induction are better designed/over engineered have better internals and seem to have better longevity
#45
SPONSOR
no...the M113K was succeeded by the M156 naturally aspired. The M156 was succeeded by the M157 Bi-Turbo. The M157 was succeeded by the M177 hot-v Bi-Turbo all completely different architectures.
#46
Sorry to revive this thread. But I was curious. Did you spend all that money they quoted you in the beginning? And then you said they call and say it hydro locked again????? That all should be on them, meaning improper work done to have it happen there at the dealer? and I would have said remove that $2k starter. So in the end before donating it what was the out of pocket expense paying the dealer for absolutely nothing? I'd just like to hear the details about it hydro locking again when the service advisor called???
#47
07 E63 + 07 CLK63CAB
The engine hydro locks after you shut them down as the coolant is under pressure and will flow to where the opening is, ie head gasket, why do these experts not pull all the spark plugs slowly turn the engine over by hand, to verify which plug hole or holes has water( coolant ) showing.
Then pull the heads off and do the job right, replace the head gaskets and replace all head bolts.
Those so called mechanics just tried to get the engine to turn over when filled with coolant, and then burnt out the starter in the process, just how much extra batteries were boosted on the original to try this starter toast. Check the battery terminals or hook up in the engine compartment.
Just shows you MB fools playing with your car and your wallet.
I trust few so called mechanics with any of my cars. Hence very few issues.
#48
#49
