OK need advice and help P0106 and hiccup, reward again offered
Old Nov 16, 2017 | 03:34 PM
E55amg0220's Avatar
Veteran: Air Force
2003 Mercedes E55 AMG
Originally Posted by oneslow55
Many don’t reset Adaptions correctly to accept this tb .i know this car like a book and little odd and ends to make it happy
im all ears brother lol
Old Nov 16, 2017 | 04:51 PM
PieRat's Avatar
CLS55
I think he means you need to go into STAR and run the throttle body re-adapt procedure. Also I believe people up the idle by 50RPM which is meant to help.
Old Nov 16, 2017 | 05:01 PM
oneslow55's Avatar
E55 amg
If the plate hangs open to long the ecu will trip
Old Nov 16, 2017 | 05:21 PM
E55amg0220's Avatar
Veteran: Air Force
Well i have upped the rpms by 50 already that was done a long time ago
Old Nov 16, 2017 | 05:22 PM
E55amg0220's Avatar
Veteran: Air Force
ok so guide me yoda i am all bout learning haha help me ojt guide me i just want it to stop haha
Old Nov 17, 2017 | 04:22 AM
bayhas's Avatar
SL55, GLS63, E550, GT and 300SE
I created a video on this recently
Old Nov 17, 2017 | 09:58 AM
  #32
E55amg0220's Avatar
Veteran: Air Force
Its a great video an id love to try it but i dont have a star yet unfortuately but ill be getting one soon. As for the idle ive already had it raised long ago anyway mine idles in gear round 600 an in park bout 700. I havent gotten any codes for a while but like i said it only happens on freeway at 70 to 80mph
Old Nov 17, 2017 | 12:25 PM
  #33
PutNavid's Avatar
06' E55 AMG, 03' E55 AMG
I had the same problem if you remember in the last thread. I redid all my gaskets too and am 100% sure there are no leaks but I got the code and hiccup 15 minutes into my first drive. Ditched the 82 and im waiting to make an adaptor plate for my 80mm.
Old Nov 17, 2017 | 12:44 PM
  #34
E55amg0220's Avatar
Veteran: Air Force
I do remember that let me know how it turns out .... i dont want to go back to stock as i love the difference the 82mm makes.
Old Nov 17, 2017 | 02:59 PM
  #35
oneslow55's Avatar
E55 amg
Guys if you need help on this pm..Sorry i didn't get back to some been busy at work..
Bayhas great vid by the way brother!
Old Nov 17, 2017 | 03:49 PM
  #36
oneslow55's Avatar
E55 amg
Don"t bro,there's many ways to go about this before the ditch..
your plate values all over the place(park,drive,and idle.
.What year is the e55 and have you done a proper smoke test with a high pressure machine?
Old Nov 17, 2017 | 03:56 PM
  #37
hayseed's Avatar
04 e55
not sure if you have seen this video ,, but if you have not it seems applicable
Old Nov 26, 2017 | 01:13 PM
  #38
Mackhack's Avatar
I have seen this P0106 come up with a bad pressure sensor/cold solder joint inside the ME engine control unit which measures the outside air pressure for calculations. Has anyone taken their ME out and taken in for a check and possible repair?
Old Nov 26, 2017 | 01:16 PM
  #39
oneslow55's Avatar
E55 amg
106 code can be triggered by intake leaks.I suggest a smoke test yearly if you drive the car hard.
Old Nov 26, 2017 | 01:25 PM
  #40
E55amg0220's Avatar
Veteran: Air Force
yeah im still tracing and and searching no leaks detected no codes and only happens sometimes usually under certain conditions on the freeway. Last 2 times on freeway did not happen ... but only thing i did different was use cruise so confused lol
Old Nov 26, 2017 | 01:47 PM
  #41
Mackhack's Avatar
I didn’t doubt any of you guys many suggestions including a vacuum leak from modding the engines. I have added a potential reason with fix. In that case it wasn’t a leak, it wasn’t a bad MAP sensor on the intercooler. It was the atmospheric pressure sensor on the ME PCB that caused P0106 to be stored as a fault.
If you have no leak because you did an amazing job putting your Kompressor and everything back together, why not looking into my suggestion instead of chasing a non existing leak or bad MAP sensor? Think outside the box
Old Nov 26, 2017 | 01:55 PM
  #42
E55amg0220's Avatar
Veteran: Air Force
Oh i wasnt saying your wrong without checking .... but this is something thats a lil beyond my repair abilities .... I am mechanically experienced and great at that not so good at electrical and how it works, how to check, and such. But i am more than willing to do it and give it a go but if you read above i havent been getting a code lately either just happens .... goes into a weird lean map and stays there til i turn car off and back on ..... so bizarre
Old Nov 26, 2017 | 04:46 PM
  #43
Mackhack's Avatar
I don’t have a reflow oven and wouldn’t do myself either. But there are specialized companies for these type of jobs.
Old Nov 26, 2017 | 04:49 PM
  #44
E55amg0220's Avatar
Veteran: Air Force
i have my tuner looking into it right now as well if he cant figure it out ill have to like you say think out of the box an this will be one of the first things i try haha. Thank you for a very good thought.
Old Nov 27, 2017 | 10:31 PM
  #45
ecmexchange's Avatar
Former Vendor of MBWorld
na
Good advice. What could it hurt? Plus, you could catch problems early on, before it all falls apart.
Old Dec 1, 2017 | 09:19 AM
  #46
oneslow55's Avatar
E55 amg
https://www.youtube.com/watch?v=Em-cLILltrE
Was he talking about shutting the bypass closed valve closed on the video ?If you do that you’ll have higher iat issues and tune will be off.You might even increase psi and have chances of the car leaning out .I wouldn’t advice that at all .
Old Dec 1, 2017 | 10:42 AM
  #47
E55amg0220's Avatar
Veteran: Air Force
Im actually looking at a possible solution to my problem. My adapter plate is welded on an im wondering if after its warmed up it has a slight warp that opens up when hot but not when shut down ..... to see if this works i decided to make my own thicker gasket. So installed it an noticed it does idle better, smoother, an so far only taken 2 trips no hiccup sooooo mine still may have been a vaccum leak thing that only reared its head when hot. But time will tell i ordered 3 of the stock metal coated gaskets an im gunna rtv them together an install as well. Ill keep everyone informed as i know
Old Dec 1, 2017 | 03:45 PM
  #48
PieRat's Avatar
CLS55
VRP mentioned it first so I guess youll just hsve to buy some more performance parts from them.
Old Dec 1, 2017 | 05:16 PM
  #49
E55amg0220's Avatar
Veteran: Air Force
Yes he did but its a weird warp lol that only happens when hot so idk lol
Old Dec 1, 2017 | 08:15 PM
  #50
Mackhack's Avatar
VRP sells overpriced repackaged crap. But back to topic.
I didn’t trust my own adapter plate either and what I did was RTV on the plate, the metal gasket on RTV, then a second layer of RTV on the gasket. I basically sandwiched it in. And I’m using MB’s RTV in case someone needs the part number.
