Bad Wheel bearing?
Old Nov 16, 2017 | 02:08 PM
WillyG's Avatar
S55 Designo
Bad Wheel bearing?
Recently ran over something in the road that fell off a truck with my factory 18’s. Replaced those with these. Now im getting a slight metal grinding/scraping/dragging sound from the front passenger wheel, I believe. Went with shorter lugs as the factory lugs would’ve been 10mm too long. The noise starts around 30 mph, and is most prominent cruising at 40mph in fifth. When I let off the noise seems to subside a little. Last time I jacked the car up to check the dust plate, I checked the front wheels for play, which there is. I took the wheel off earlier, put a Long stud into the hub to spin the wheel faster. When I did I could hear what seemed to be little b bs rolling around/light clicking. Wheel bearing I guess?
