Think airmatic relay went out, Can you manually raise the car with 12 volts?
Car wont raise up. Can't hear the airmatic pump. Airmatic malfunction on dash. airmatic pump fuse is good, ordered new airmatic relay from MB. Thinking it could be airmatic relay its the original one from 2005.
Anyone have this issue? I put 12 volts directly to the airmatic pump and it turns on. My question is if I continue to power 12 volts to the pump will it raise up the car? The new relay from mb wont arrive till saturday. So what do you guys think?
Anyone try this? Any help would be appreciated. thanks.
Merry christmas!
Any other suggestions? I have my old pump that I can swap out. But, the pump does not turn on at all with a new relay. Gonna check the wires going to the pump to make sure its not damaged. I was sure the relay would be it. Because the pump did turn on with 12 volts.
Do you know how often the pump comes on during normal driving? If you leave it in comfort or raised up and dont lower or raise it at all. Will the pump not come at all? Or does it come on every day during normal driving? Anyone know?
I just put new airmatic struts on front and rear. So hopefully not those.
today I replaced the compressor but have no power to compressor. It came with a relay but i am struggling to work out where it goes.
all answers from Google say its in different places. Very confusing.
it's a 2010 E220 CDI estate.
Any help would be great.
Thank you
