Max Boost
Old Dec 10, 2017 | 09:03 PM
SICAMG's Avatar
2005 e55 AMG
Max Boost
So there are many pulley combo's out there with a lot of ten second cars. so the question is "How much boost will these engines tolerate on a daily basis" ? Aside from needing a map clamp of course and heat issues.
Old Dec 10, 2017 | 09:50 PM
oneslow55's Avatar
E55 amg
Ask yourself this would you push a engine with weak rod bolts and glass pistons ??After a certain amount of boost I would worry about the heads lifting too.Dont push this engine past 15 psi daily on pump .
Old Dec 10, 2017 | 09:54 PM
The Fly 1's Avatar
E-55,IS-250
from what I read anything over 17.5 you will run into problems.
Old Dec 11, 2017 | 02:06 PM
SICAMG's Avatar
2005 e55 AMG
Cool just wondering!!
Old Dec 13, 2017 | 01:56 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
aka 70mm SC pulley is the limit, or stacked setups:
180 - 83 =
168 - 76 =
70mm SC
headers can help drop the boost pressure
Old Dec 13, 2017 | 02:00 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
15 psi or less to be safe UPD 77mm will produce that
