Coolant Flush
1. For sure he didn't drain coolant from engine block because he didn't even remove the engine under tray
2. He used tap water to mix (Will this eventually ruin my cooling system?)
3. Was 1 gallon of concentrate antifreeze agent enough?
The temp was around 100 - 103 c degrees for my daily drive. After the flush, the temp now is around 110 degrees, the highest is around 112 for 30 minutes driving. I don't feel it right. Should I get it redone? Am I being worried too much?
I guess that's why I do my own work...
I agree with you.
And, I find the combination of your username and signature quite ironic.
When I recently rebuilt my motor at 120k there was zero corrosion present when using a bore scope and I am sure I used tap for a few of those flushes. As my car sits often I used distiller on the last flush as I have a stock pile of end of the world supplies I rotate through.
And finally you do not have to run Mercedes only fluid, and there is no appreciable improvement using it. Just adhere to the maintemance schedule and your GTG.
A coolant flush shouldn't change the temperature the engine runs at, regardless of the type, ratio, amount drained, etc. Are you 100% sure the temperature changed? (I'm not saying it's in your head, but in most cases, it is--just like all the people claiming their car runs better after an oil change or they can tell when it's due based on how it runs). The engine temperature is controlled by the thermostat: as long as you have some fluid in there that is somewhat good at transferring heat, the temperature should stay pretty must the same.
The coolant should be mixed in roughly a 50/50 ratio with water. There's no way to know exactly how much coolant you will need to add because it never all comes out: the only way to ensure a correct ratio is to pre-mix it. If he poured a gallon of coolant in and topped it off with water, that is definitely NOT the correct way, but it is a pretty common method and usually results in a mixture that's close enough (most likely it's got a bit too much coolant and too little water, which isn't ideal, but is safer than too little coolant). If you want to be sure, just test it with something like this:
Mixing the coolant with distilled water is technically the "correct" way to do it and is definitely the best practice, however, unless there's something really wrong with your tap water (a LOT of minerals, for example), I wouldn't worry about it. I work for one of the largest MB dealers in the country and all we ever use is tap water and we've never had any problems that could be related to that practice. I don't know about other areas of the country, but as far as I know, all of the dealers and shops in my area use tap water. That said, we do have pretty good public water here. If you have well water or aren't sure, it's certainly not a bad idea to used distilled water.
sjc246: Good info, thanks.
