2009 E63 Radio problem
Old Feb 2, 2018 | 05:03 PM
PAULSGTS's Avatar
2006 z06
Hey guys i just recently picked up an E63 and the radio turns on and and works for 35 seconds then it shuts off for 8 seconds then turns back on. The radio keeps on doing this unless you shut it off then it will remain off. I did send the radio out for repair but the company called and said it was working perfectly when bench tested. I did have power going to the radio when it shut off and did check the grounds.
thanks for the help!
Paul
Old Feb 8, 2018 | 11:18 AM
Infiniti's Avatar
a unicorn tuned p30 e63
your problem may be coming from the audio gateway.
Old Feb 8, 2018 | 11:50 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
There are so many software issues with the audio systems in these cars (or any of the systems really). You may have to find somewhere (probably the dealership) and see if they can update the audio/telematics system software.
Old Feb 8, 2018 | 12:52 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
with the MB MOST audio system, if any component of the loop is failing, you'll see your head unit reboot. to isolate you'll need to purchase a loop isolator and eliminate each device.
additionally in my own experience my same issue was resolved by cleaning and reseating the battery terminals. i battled this issue for 8 months with the result being battery terminal's being slightly dirty preventing a solid connection.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
