Transmission Problems
Old Feb 14, 2018 | 10:15 PM
E55chuck's Avatar
2006 E55 AMG
I have been having some transmission problems on my 06 e55. It all started the other day when i was driving. I was pressing the gas and all of a sudden it just revved instead of moving. I kept pressing the gas and it kept revving. I pulled over and shut it down. A few minutes later it was normal. Then it happened again. A few moments later there was no response from the transmission. The next day it was fine, but the check engine light was on and there was a new whine coming from the transmission, sounds like a dental drill. The car keeps losing power when driving and will even rev when its in drive. I also tried to shift gears but it will not change gears. WHAT IS GOING ON!
Old Feb 14, 2018 | 10:18 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Is the fluid level correct? Got any visible leaks?
When's the last time the fluid/filter was serviced?
Old Feb 14, 2018 | 10:20 PM
E55chuck's Avatar
2006 E55 AMG
i don't have the dip stick and it isn't leaking
Old Feb 14, 2018 | 11:44 PM
tw2's Avatar
tw2
Get a STAR scan.
Old Feb 15, 2018 | 06:49 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
It's the fluid. Get it check and refill.
Old Feb 16, 2018 | 05:54 PM
2013 ML350 Bluetec
And: If you don't know when the fluid was last dumped/filled with a fresh filter, this is probably a good time to do that service. Seems like I've read on these pages where a clogged filter caused exactly the symptoms you describe.
Old Feb 16, 2018 | 06:14 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Buy yourself a dipstick from Ebay or somewhere. It is most likely the fluid level being too low. If it is low, check if the cable from the TCU to the transmission (wiring connector) isn't leaking also. It is usually low for a reason. I would change out the filter and gasket if the car is in this state. Very easy to do.
Old Feb 19, 2018 | 08:38 AM
MACEDON's Avatar
05 E55, 98 CLK320
Mine did the same but the fluid and filter were done a year ago. It also started whining like crazy. It's at the shop getting looked at now.
Old Feb 19, 2018 | 09:42 AM
cm60k's Avatar
Happened with my friends 05 E55 last year,,
he had a crack speed sensor in conductor plate & bad fluid, besides little bit oil sneaks to the TCU..!!,,
hope your issue less that that..
-;ZAYED;-
Old Feb 19, 2018 | 10:22 AM
Hoppled's Avatar
MB W211
the reason i registered here and wanted to talk with you people is because i also have problems with my w211 with the transmission, tires from https://www.neotires.com, thanks for suggestions, at least i now have more ideas about what to check. may i ask you questions in case i would have some? thanks again everyone.
Old Feb 19, 2018 | 10:54 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Originally Posted by Hoppled
the reason i registered here and wanted to talk with you people is because i also have problems with my w211 with the transmission. thanks for suggestions, at least i now have more ideas about what to check. may i ask you questions in case i would have some? thanks again everyone.
Make your own thread. You'll get more info than if you piggyback on someone else's.
Old Feb 19, 2018 | 02:38 PM
E55chuck's Avatar
2006 E55 AMG
keep me updated
Old Feb 21, 2018 | 03:05 PM
MACEDON's Avatar
05 E55, 98 CLK320
Still waiting on the mechanic.
He said it was the timing chain at first I was like wait WHAT?? Then I explained to him what actually happened (went limp, then wouldn't shift up). Still waiting
Old Feb 21, 2018 | 03:56 PM
tlambert's Avatar
2005 E55 AMG
Went limp and then wouldn’t shift up!!!??? Damn you need to see a Doctor not a mechanic. Lol
Old Feb 22, 2018 | 08:17 AM
MACEDON's Avatar
05 E55, 98 CLK320
That would at least be cheaper than what's coming to me
Old Feb 22, 2018 | 06:56 PM
Redwood415's Avatar
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
do fluid and filter service and keep fingers crossed for no permanent damage. Service 1st..
