55Kompressor
55Kompressor
hey guys. So this is my first post up on MBWorld. So let me start off with an introduction. I have a 2004 Sl55 Amg. My current mods so far are straight pipe with X pipe and stock mufflers, and a ECU/TCU flash and grippy tires on the rears. My 1/8th is a 7.7 and my 1/4th is about 12.1 with high heat temps.
My goal is to make the car a drag strip car that can hit high tens.
I currently have my garage filled with parts so I can do one big install.
BWK
Colder spark plugs
630cc Injectors
Injector harness
Killer chiller
Trunk tank
Lowering links
Bosch IC pump
Needswings Cold Air intake with gold thermal coating
178mm ASP Crank Pulley
I am also planning on adding a 83mm clutched S/C pulley. Then my boost should be at around 15.8 pounds. In the boost chart that shows right in the dark green. I also plan on potentially adding meth down the road.
now you might be asking why am I posting this in the e55 forum when I have an Sl55. Because it’s engine related and I assumed you guys would have more knowledge basing that their are more e55 drag cars than Sl55.
I was thinking about adding a small 25 shot of nitrous. This would mainly be for the launch, id spray to get off the line a bit quicker till my s/c can engage.
Of course I’d get slicks or DR for the rears so I have traction. But any optinions on this? I know some members have used nitrous but I don’t know if it is a safe thing to do on these engines even if it is a small shot. Let me know! I appreciate all feedback!
BWK
Colder spark plugs
630cc Injectors
Injector harness
Killer chiller
Trunk tank
Lowering links
Bosch IC pump
Sounds like you are on the right track. The very first thing you should do is start logging. Even if it's just a cheapo ELM327 OBDII logger you can get good info about your IAT's, timing, and boost.
How much does the car weigh? Aren't the SL's even heavier than the E's?
You are posting in the right place! Make sure you have enough fuel pressure. #8 has a tendency to lean out. One of the companies on here sells a slightly larger injector for that hole.
The guys with real world experience and knowledge drop by here from time to time, be patient. (Joe is one of them).
2005 E55 AMG, 1991 MR2
I have heard of people flow testing them all and putting the highest flowing in number 8.
Last I checked it seemed that the looped rail didn't help much and most lean issues were put down to clogged fuel filters and or dying pumps.
I have no drag racing experience but I can't see anyone needing nitrous to get off the line. Traction is the enemy.
This forum was a lot different 5 years ago, The guys were right on top of all this stuff. I'm sure companies like Eurocharged still remember all the correct answers.
I'm just assuming the SL55 motor has the same fueling problems as an E55 and a CLS55. I don't know that from experience.
And no I would never do this as I already stated, I believe most issues are down to poor fuel pressure due to fuel filters or pumps. And yes I believe custom dyno tuning with correctly sized injectors and pumps is the best way to get ideal AFR's when you are pushing things to the limits.
Thanks man. Let me reiterate just in case you are misunderstanding since I find it absurd you can't follow the logic- take all 8 of your stock injectors, clean and flow test them, they are all going to be roughly the same with slight variance, maybe 20cc difference from lowest to highest. Then put the highest flowing of them in the spot most likely to be leanest. They all worked on the stock ecu before unless you are claiming changing the same injectors around different cylinders somehow means the stock ECU cannot use them anymore...
No ,logic is not there to follow .You can’t toss large injector in that cyclinder without a stand-alone and have proper afr !If you can’t understand this then not sure
Only large enough to equalize it, so #8 has the same afr as the other 7 because it tends to run leaner. If you overcompensate then the point you are trying to make is true.
I was just trying to give the new guy a heads up so he didn't trash his motor right out of the gate. #8 has been the most common failure point over the years if you don't count valve cover gaskets.
Many in this platform don’t understand how the fuel system works and keep doing the other person mistakes .Just cause you run larger pumps won’t solve your cylinder lean out too,there’s more to come to play
Maybe download one of those programs on your computer that will read things out loud for you. You make comments and recommendation on every thread based off of either the inability to comprehend/read other peoples posts or reading 1/4 of topic and assuming you can correctly guess what the rest of it is.
tw2 (03-11-2018)
BWK
Colder spark plugs
630cc Injectors
Injector harness
Killer chiller
Trunk tank
Lowering links
Bosch IC pump
BWK
Colder spark plugs
630cc Injectors
Injector harness
Killer chiller
Trunk tank
Lowering links
Bosch IC pump
I have read lots about it, cnterline above can probably chime in more on that topic
One slow you make it very clear that you don't read well in most of your posts, but if you read TW2s post very carefully, or have some one else read it for you, you will see that he is not recommending putting in one bigger injector. Yes, he mentioned some one may sell a set up for that at the beginning of this thread, but the comment he made that you quoted is simply recommending putting the highest flowing of the STOCK injectors in the number 8 spot. He typed it twice for you to help clear up your obvious confusion yet you keep going back to the larger injector thing.
Your a (idiot mr.internet lawyer) ,centerline just said it lol..Your clown you can't add a larger injector without standalone in this car with it running correctly .You can't add one large with the rest stock and what you going to do scale on only??Love to see this on a stock ecu,.This forum I tell you are special people...Learn how this car works and report back on ecu ,injecotor and tables the ecu has to make the ecu work with it open loop.
Again, you have failed to read/comprehend what was said.
