Wheel gap question
Old May 5, 2018 | 07:29 PM
Kokopelli's Avatar
2003 E55
Wheel gap question
I just swapped the airmatic suspension out for a BC racing coil over setup and now need to set the ride height. I'm running on 19's and the car currently has 1/2 inch wheel gap in the rear and a 2 inch gap in the front. What is a safe gap to run to avoid rubbing?
Old May 5, 2018 | 10:05 PM
Hotsauce55's Avatar
2005 E55
I think the coils are going to settle over the next few weeks, I suspect the rear is too low & keep reading it’s a pita to adjust.
bit of trial and error so start higher
Old May 7, 2018 | 08:48 AM
Kokopelli's Avatar
2003 E55
I have about a hundred miles on the car since I installed them so hopefully they have settled in. I dropped the front a little and it looks much better but damn those rears are impossible to get the wrench on. I may end up dropping the control arm and pull the spring out to make the adjustment.
Old May 7, 2018 | 09:35 AM
Hotsauce55's Avatar
2005 E55
What distance do you have between the perches?
i am trying to get the right distance the first time
Old May 9, 2018 | 03:11 AM
jumph4x's Avatar
W210 DRFT BNZ
Check out last pages of my thread for the best way to adjust. Saved myself hours already and only figured it out a week or so ago.
