Did I just contaminate my radiator/transmission cooler with glycol coolant?
I bought a 2005 S500 about a month and a half ago which was hit from the front. I took off the whole front clip with the intention of replacing it with another. The radiator was damaged so I took off and threw away the damaged ones. The car is NOT inside a garage, it's just in the yard with the bonnet still on. I didn't end up finding a replacement clip in time and had to go overseas for a while. So it's been a month roughly and the car was sitting outside with all the lines open.
Now I ended buying a complete rear ended car which was totalled and took off the radiator/condenser. While I was carrying the radiator, I had the expansion tank still attached and as I was carrying over to lay it flat, a few drops of coolant from the expansion tank hole conveniently went in the hole for the ATF.
I know glycol contamination could ruin a transmission so now I'm worried I stupidly ruined this radiator and if I install it I could contaminate the ATF with coolant.
This is really retarded, I realize this but what do you guys think I should do, from leaving the lines open that long to this stupid problem.
1. Leaving the lines for that long, could enough moisture have found its way into the system to cause issues?
2. What should do about the radiator. Should I just find another one or flush out the ATF part with ATF?
Thanks for the help.
But yes I would clean the inside of the transmission and engine coolant parts of the radiator. I presume your parts car is post 2004?
