Hello i have problem with my w211 fuel pump wire buring and its burn the sam
Replace fuel pump. Replace fuel filter. Replace fuel pump relay (lowest one on the rear SAM). Verify fuse #4 on rear SAM is 15 amps and that the blades have no corrosion. Obtain new connector and sockets from dealer, aftermarket electrical supply, or from donor car in salvage yard. Repin the connector (do NOT attempt to reuse that burned/overheated socket in that connector). Thoroughly clean the pins on the SAM (assuming SAM is still good); if SAM is burned out, obtain a replacement and have it coded for your car.
In future, replace fuel filter and pump on regular basis.
