IAT’s Seem High
Old Jun 23, 2018 | 12:03 AM
karpetcm's Avatar
2006 E55 AMG
IAT’s Seem High ( UPDATE )
I just got my OBD2 Module and downloaded Dashcommand. I was looking at IAT and 189-192 At cruising and 205 after Wide Open Throttle. Is that correct? Seems high to me for some reason. I did repeated runs, same results. I havent yet installed my superflow pump going to do that soon. Also is the Horsepower measurements to the wheels or crank when it reads it on dashcommand app?
UPDATE: I'll Post my update up top so no one has to scroll down through all the posts.
So I drive home today after the install of my Superflow Pump. Went and saw Chris in Costa Mesa STAR MOTOR WERKS recommended by member Das_it16
Outside Temp 80 degrees coolant temp 190-195 and IAT's at cruise 65mph 91-93 degrees and wide open throttle 117 degrees. As soon as I lift off the temp as quickly as they went up and they go up quick they quickly within 5-10 seconds go from 117 to 100-105 and then 45-1:00 later down to 93 degrees again. Did it a few times with the same results. Now it trips the traction control light at 60+mph when I floor it no problem. Just a totally different car now. So glad I did this and upgraded the pump. I went from 160's cruising best case scenario to 90-95 consistently.
Old Jun 23, 2018 | 06:31 AM
equitiesguy's Avatar
Mercedes CLS 55 AMG
Your intercooler pump is bad. Temperatures that high means you have no cooling to the circuit whatsoever.
Old Jun 23, 2018 | 02:46 PM
karpetcm's Avatar
2006 E55 AMG
So i figured lets try it again because yeaterday late afternoon was hot 90+ degree weather. Today 77degrees outside i do a few wide opens and temps get up to 176-180 cools back down 1-2 min later to 162-165 cruising. So alot better then yesterday granted temps outside are alot lower.
Yesterday IAT’s matched coolant temp 200-205 coolant temp and IAT’s after a couple of light hits of throttle 205+. Today coolant temps tad better 198 but IAT’s lower still not sure if its any good. I still need to change that pump. Just sitting on my desk.
Old Jun 23, 2018 | 10:26 PM
SICAMG's Avatar
2005 e55 AMG
Listen to this guy!! Your way to hot....pulling lots of timing for sure !!
Old Jun 24, 2018 | 08:46 AM
Mercedes CLS 55 AMG
Your intercooler pump is defective, and needs to be replaced.
Old Jun 24, 2018 | 08:47 AM
f8l ws6's Avatar
2005 E55
My car will usually be 10 - 15 degrees over outside temperature while just cruising. Usually gets to the high 120s on a quick run then drops back down to normal pretty quickly.
Old Jun 24, 2018 | 08:50 AM
Mercedes CLS 55 AMG
+1. My car is the same.
Make sure you replace it with the upgraded Bosch pump (0392022010). Can buy it at Autohaus for $108 genuine Bosch. No matter where you buy it, just make sure it's a real Bosch.
Old Jun 24, 2018 | 08:54 AM
f8l ws6's Avatar
2005 E55
Thumbs up
This is the pump I run as well. Works great and highly recommended.
Old Jun 24, 2018 | 09:02 AM
Mercedes CLS 55 AMG
Most of Bosch's redesigned parts for these 55s are terrific. This updated intercooler pump, and Bosch's updated UFO type starter are two prime examples.
Old Jun 24, 2018 | 09:20 AM
karpetcm's Avatar
2006 E55 AMG
I’ve got the superflow pump sitting on my desk in the next couple of weeks ill get it installed, hopefully that will help. Anyone know of a good shop in los angeles areas that knows our cars well? If i take my pump for him to install he knows what he’s doing.
Old Jun 25, 2018 | 01:01 PM
Das_it16's Avatar
2004 E55 AMG
Contact Chris Mattox over at Star Motor Werks. He works on a lot of AMGs from the AMG SoCal Lounge Group on Facebook. Never heard any complaint from his shop.
https://www.yelp.com/biz/star-motor-...s-costa-mesa-5
AMG SoCal Lounge: https://www.facebook.com/groups/amg.socal.lounge/
Old Jun 25, 2018 | 03:40 PM
karpetcm's Avatar
2006 E55 AMG
I gave him a call, seems to be a really nice guy. Will be there tomorrow morning to get it done. I'll ask him and see if I get a trunk tank split system how much he will charge to install it for me as well. If he is reasonable I will go back to him have him install it when I get it. Thank you by the way.
Old Jun 26, 2018 | 06:00 PM
karpetcm's Avatar
2006 E55 AMG
updated at the top.
Old Jun 26, 2018 | 06:03 PM
Mercedes CLS 55 AMG
That's what ten degrees of retarded timing does to an engine.
Old Jun 26, 2018 | 06:12 PM
karpetcm's Avatar
2006 E55 AMG
for sure, the car felt terrible before, every once in a while it would pull decent when cold but after that it felt very slow and sluggish which hence when I first got the car I was posting on here why it didn't feel MUCH faster then my e550 I have. After talking to Chris at the shop today I'm gonna go with a 83mm pulley nothing smaller and split the cooling and call it a day. I'm not gonna go major on the car. It has too many miles and I want to enjoy driving it now. A few years from now I'll just buy a 2014+ E63. I'm back in love with my E55, wow what a difference.
Old Jun 26, 2018 | 06:14 PM
Mercedes CLS 55 AMG
Waste of time and money. I could probably name a half dozen things you need to do to your car before any kind of upgrade would make a difference.
I also wouldn't recommend buying an E63 with an inherently defective engine. But that's just me.
Old Jun 26, 2018 | 06:54 PM
E42AMG???'s Avatar
E420
thats why it isn't your car
Old Jun 26, 2018 | 07:04 PM
Mercedes CLS 55 AMG
Couldnt be more true. My car is maintained and runs properly.
Old Jun 27, 2018 | 04:16 PM
Davednconfused's Avatar
2005 E55 AMG
I'm pretty sure a smaller pulley and split cooling would make a noticeable difference on even the worst maintained 55 car...
Old Jun 28, 2018 | 07:42 PM
karpetcm's Avatar
2006 E55 AMG
This is a screen video of me doing a Wide Open Throttle Run.
Old Jun 29, 2018 | 03:32 AM
tw2's Avatar
tw2
I doubt split cooling makes a difference on any car.
What's wrong with the 2014 E63 engine? (yes I could just prowl their sub-forum).
Old Jul 23, 2018 | 10:51 PM
Das Geld 2's Avatar
SL55, S500
Amazing, mine hit 200f and took 5 min to go back to 185 LMAO!
How much HP loss is that?
Old Jul 24, 2018 | 07:19 AM
PieRat's Avatar
CLS55
If it goes into limp mode like 80% loss...
Old Jul 24, 2018 | 07:58 AM
MACEDON's Avatar
05 E55, 98 CLK320
Holy hell man you're driving with the supercharger disengaged at all times basically.
Go get that new pump asap.
You should be seeing cruising iat's no higher than 30F above ambient if you live in a hot state like me.
Old Jul 24, 2018 | 10:16 AM
Das Geld 2's Avatar
SL55, S500
Right you would think that but the thing pulled like a freight train ran a CL63 neck and neck to 100 from 40.. -.-
When I took it to the useless dealership 2 months ago and told them my PUMP is dead they laughed it off(It was 65f at the time and prob 0 humidity)..now I have proof. ofc, my extended warranty is dead now and I'll need to install the 010 myself, I had one laying in my trunk for months.
