AC oil capacity
Old Jul 22, 2018 | 04:44 PM
mAMG's Avatar
SL55 2003
AC oil capacity
Hi all,
My car started making noise from the AC compressor. Changed the AC compressor and dryer as per mechanic recommendation.
After a week, the compressor started to make noise again but you barely can hear it. I believe they mechanic did not fill the AC system with the correct amount of oil.
Should I get another compressor ? Or just fill the current one with oil ?
How much does the AC system oil needs ? Is it filled only in the compressor or also charged with the R134 ?
thanks
Old Jul 22, 2018 | 05:18 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Old Jul 22, 2018 | 10:47 PM
mAMG's Avatar
SL55 2003
Originally Posted by bbirdwell
okay so since my mechanic flushed and cleaned the system, i have to add 120 cm3 to the compressor and 160 cm3 when charging the R134 ?
Old Jul 22, 2018 | 11:16 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Without knowing what your mechanic did, *if* the system was completely replaced and flushed, it would take 120 cm3 of oil. The other quantities are for replacing individual parts without flushing the entire system.
Old Jul 23, 2018 | 07:53 AM
mAMG's Avatar
SL55 2003
system is completely flushed, only compressor and dryer replaced. So its 120cm3.
Thanks alot
