R230 ABC Coding Issue
Old Jul 30, 2018 | 01:12 PM
layzie12g's Avatar
2008 Mercedes Benz E63
FIXED: There is another portion of coding in the cluster that needs to be set to not present. It was not taking the coding because a portion of the NAV in the cluster was not coded.
I have a client's car in with coil overs and am unable to code out the ABC. It has been coded out of the cluster as per a search would suggest. That did not work. I still get a white ABC Malfunction. I went and coded it out of central gateway and even went in to developer mode and coded it out of the ME. Any help would be appreciated.
Old Jul 30, 2018 | 03:09 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
Headlamp range control?
Old Jul 30, 2018 | 10:47 PM
layzie12g's Avatar
No. It had to do with the COMAND and navigation.
