Oil Level Need Help
Old Aug 18, 2018 | 03:27 PM
karpetcm's Avatar
2006 E55 AMG
Oil Level Need Help
i bought an aftermarket oil level dip stick. Ofcourse the ebay seller has no clue the chart he provided which one is to my exact engine ill post pic. There is 3 M113 options on the chart. Would any of you guys know which is correct. Im at 90 on the oil level, my car 06 E55.
Old Aug 18, 2018 | 05:14 PM
Rallyboy383's Avatar
2004 E55
Triple check that oil level! Your level should be at 168 on your dipstick! 90 seems REALLY LOW! Are you getting error messages on yiur display?
Old Aug 18, 2018 | 05:18 PM
karpetcm's Avatar
2006 E55 AMG
I got no error messages and no weird sounds from motor.
Old Aug 18, 2018 | 05:29 PM
2004 E55
Are you sure you are inserting the dipstick all the way? Do you have a pic of the dipstick inserted? I can tell you if it is fully inserted.
Old Aug 18, 2018 | 06:05 PM
karpetcm's Avatar
2006 E55 AMG
Best i can do is 100 wont go anymore.
Old Aug 18, 2018 | 06:29 PM
2004 E55
Looks like you are low. I wanted you to make sure becuase i do not want you to overfill your engine. I am surprised that you do not have any messages stating that you need to add oil. Oil sensor malfunction? Triple check the readings on the dash for any message(s) and procede to add oil. 0w40 is what you should use. 168mm is your stoping point.
Old Aug 18, 2018 | 06:38 PM
karpetcm's Avatar
2006 E55 AMG
Not turned on or warmed up just only turn the key to check oil im at 5.8 qts
Old Aug 18, 2018 | 07:06 PM
quikv6's Avatar
87 Grand National; 2006 e55
5.8 on a cold car (where all the oil is in the sump) seems quite low. That number is going to drop when started, as the oil cycles. Usually if I check electronically with matching cold conditions, I'll be around 7.5 give or take a tenth.
Old Aug 18, 2018 | 07:22 PM
karpetcm's Avatar
2006 E55 AMG
Then im gonna add 2 qts and re-check. Thanks for all your advice much appreciated. Not sure why it gave me no warning thats very bad.
Old Aug 20, 2018 | 09:58 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
You should have just bought the correct one from the dealership. Trying to save a few bucks buying cheap Chinese crap, never works out in the long run.
Old Aug 20, 2018 | 10:14 AM
tlambert's Avatar
2005 E55 AMG
Cheap Chinese crap is basically all we can get now. Unless it’s from the dealer.
Old Aug 20, 2018 | 05:59 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Are you sure you're not checking the transmission fluid? Why not drain the oil, add 9.5 quarts, then measure? You are risking a $30K engine on a cheap dipstick and you do not appear to be willing to invest in $46 worth of Mobile at Walmart. Let us know what happens as this may be a learning experience for us all...
Old Aug 20, 2018 | 06:01 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Plus the instrument cluster will tell you, "Add one quart oil at next stop". If this is messed up, then replace the oil level sensor.
Old Aug 20, 2018 | 06:03 PM
karpetcm's Avatar
2006 E55 AMG
im not parked on a level surface either so i gotta park somewhere more level and then have the computer check it again to be exact, regardless its still gonna be low. I’ll change
the oil sometime this week, haven’t driven the car in days.
Old Aug 21, 2018 | 08:10 AM
hayseed's Avatar
04 e55
this is your best option - no guessing
Old Aug 21, 2018 | 01:44 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
^ agree'd. this is how I confirmed that what others said about the replacement dipstick for the M156 was true. It reads 1.5-2 quarts low.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 21, 2018 | 02:18 PM
Yuille36's Avatar
To be totally forthcoming, after draining both the oil pan and oil cooler, I put in 9.5 qts of Mobil 1 0W-40. I then warm up the car and take a reading, to ensure the correct oil level.
After that, I never check the oil again until the next change, or if the car tells me to add an additional quart at next fill up. I've done it this with all my cars.
If their is an issue, the car is smart enough to notify me, of the issue. And during the 11 yrs of ownership, the add another quart, has only appeared a few times.
So my car really burns very little oil, between oil changes.
Old Aug 29, 2021 | 07:27 PM
Wizo's Avatar
E55 AMG, Audi Q5 TDI
How far are do you insert the dipstick tool? (Baum 120-0721)
I’m having a hard time determining when it bottoms out. I have to force it and can actually insert it all the way. It feels like 810mm is the bottom out point. However I read oil level of 180 which is over full per dipstick instructions. My dash reads 6.5qts/OK. This last oil change I added 7.5L, hesitant to ad more as the sensor and dipstick aren’t lining up. Worried about user error on the dipstick insertion depth.
Insertion depth
Oil Level
Old Aug 30, 2021 | 07:03 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
It says oil level OK at 6.5 on the cluster? Odd. Mine tells me to add around 6.8 and 7.8 reflects a full 9 qt oil change.
