Maxbore can NOT bore the molded actuator TBs
Just wanted to post so hopefully no one does what I did. If you have one of the throttle bodies with the giant stupid rubber mold covering the actuator he can not bore it. Which obviously makes perfect sense since he removes the actuator and bores it and cuts a new butterfly and what not but it just didn't click to me until he emailed be and said he couldn't.
He was actually very good about it and fully refunded me and shipped it back so he really just lost money on the return shipping, and I was out the cost of shipping it to him. So just to help prevent the same mistake I wanted to make a post about it if any one is searching for info on it or something maybe I can save them some head ache. Only send throttle body types with the removable plastic cover over the actuator and not the stupid giant rubber molded cover :hammer: |
Uhhh...the rubber molded cover comes off. Sometimes you'll need to use a utility or exact-o knife to cut the glue first as you peel the rubber back.
Does it have a regular plastic cover under or do you have to re-glue it back on?
It has the plastic cover underneath. If you carefully remove the rubber cover without destroying it, you can simply put it back in place, it kind of wraps around the plastic cover and holds itself in place without glue. I imagine Maxbore doesn't want the liability of removing it, or doesn't want to spend the time.
That's great info thanks. I will rip the TB apart when I get home this weekend! Will report back for a little more data after it's done.
I did have email conversations with him before and after I sent my TB, it seemed very much so that he was not aware that the rubber was just over top of the plastic cover. But I will make sure he knows now and he can give any other E55 customers a heads up if they don't know. |
What's the plan forward, you going to send it back to him if you can get the rubber off? Unfortunately I live a bit across the pond so I don't have the luxury of sending mine away for a bore job, but thinking of just doing a shaft grind.
Yep plan now is to get that stupid cover off and send it in again haha. I did the shaft grind within the first week of having the car! Haha :naughty:
Anyways ya, I already bored the SC snout so gotta get that TB done. |
Originally Posted by drothgeb
(Post 7558056)
Originally Posted by C32owner
(Post 7558972)
Did you notice a difference after the shaft grind? Gonna be interesting to hear your thoughts after the lipo suction job coming :naughty:
Originally Posted by E55Greasemonkey
(Post 7557341)
