80MM Pulley Install and My Opinion
80MM Pulley Install and My Opinion + EC Tune
Well let me tell you after 4 hours to get this installed at my local mechanic shop I was off and driving, this was more so the mechanic hating after market parts and never installing a pulley on a e55 and as well not listening to me telling him you go about it in a certain way, lol what mechanic does like being told how to go about it
. Getting that bolt off to get the pulley off was a PITA. It took forever and a trip to Home Depot to get it done. It was on there tight and just gave a really hard time. I got the 80mm on and used the single washer it came with. Has a very very slight scrape that I can only tell but other wise it spins and no wobble. Also when with a smaller HD belt to compliment things and keep it from slipping.
Now for the drive. I honestly feel it being more torquey then it gaining more horsepower. I really don't feel up top in the rpm's it pull that much harder for me to say wow that's so noticeable but the torque yes for sure. I thought before when I was doing 70+ you tap the gas pedal and it would jump forward now it's more pronounced and obvious. The car does feel jerky like once in a while it will jerk when i tap the throttle to quickly. Not sure what that's from. Overall I'm pretty happy with the install.
Next i gotta get my secondary Heat Exchanger Installed and get them to wire the IC pump with the Ignition. From there I'll decide wether i should do a 2.5 Tank and Killer Chiller or not. I still got a ways to go in modding the car but for now I'm pretty happy with the power.
Edit : Never mind, just read your other thread that you did load a tune. Must say when I went from stock pulley to 84mm and tune there was only 15rwhp difference, needless to say very dissappointing, I could not tell the difference. Disclaimer... I am at high altitude.
Did you get a tune for the new pulley, or just install and go on stock tune?
The buck is pretty normal unfortunately, as you put a smaller SC pulley it's a little more dramatic on the motor when that clutch locks up. The clutch always engages above 3500 rpm but you have to be very light on throttle for that. So depending on how you're throttling you'll get that clutch engage usually in the mid 2000ish RPM range.
ok perfect im glad its normal. Thank you.
Would it help smooth out the SC engagement if you added/removed shims? My stock pulley bucks (and chirps) at low speeds when it engages at around 2000ish RPMs, but engagement is smooth (but still chirps) if I'm easy on the throttle and it engages at higher speeds (as drothgeb mentioned). I was planning to take the pulley off and play around with the gap
over the years of modding i came to a certain and positive conclusion that most aftermarket parts you put on your car are simply no where near engineered as the stock parts and if you go aftermarket there are some pro’s and con’s and that’s the risk we take. So if it bucks/hesitates and that’s the way it is I’ll live with it. I knew looking at the shim i got and the stock one it was going to be useless trying to invest lots of time getting the right gap. I put the one shim it came with gap was close enough after trying to test fit another shim and said I’ll stick to one and move on. Granted there are very good quality aftermarket parts butttttt another unknown is how well there installed. I’ve installed long tube headers excellent quality and a very highly recommended and reputable mechanic, broke my oil pressure sensor during install never mentioned it. Going home 1 am car puked oil all over the freeway.
I just kick the clutch on, quick light stab of the throttle, at say 2,000 rpm when I know I am going to play and I have it down to where you can't really notice it. Will stay on forever until I come to an idle. Mine also can be abrupt if I don't do this as my pulley combination , 168-74 upper is a wee bit aggressive.
I'm really leaning towards getting a BWK either way so ill do that next. I really need to find someone reputable to install my secondary heat exchanger in my area most people look at me funny when I ask them to install it. Have no clue as to what I'm talking about, lol.
FunkTron (09-24-2018)
That is the only way you can fit an impact wrench on it (radiator isn't necessary). Some pulley bolts you can't remove any other way.
ya for sure lol, it took me over an hour to convince the guy who changed my pulley on how to do it. He was talking about removing the fan shroud, radiator and jack up the front of the motor to get the angle. I'm like WHAT. Dude you just need to do this, he was soo hung up on doing it his way it took way longer then it needed.
