Oil Geyser from Filler Cap
Old Sep 30, 2018 | 10:10 PM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
Originally Posted by N_Rob
I wrapped the oil filler neck and filter cap in aluminum foil and recreated the leak. To my surprise, it was neither of those. might try wrapping the individual lines next and seeing if I can isolate it that way
OK! Good work, good plan. You'll get it. Looks like you may want to check your motor mounts as well. Staying tuned for the conclusion!
Old Oct 1, 2018 | 11:54 AM
N_Rob's Avatar
2008 BMW M5, 2004 E55 AMG (RIP)
I found a TINY tear in the bottom of the two lines right in front of the filtercap, I’m hopeful that this is it. Looks very small for the amount of oil that came out but there is a lot of pressure up that high in the rev range I guess. Hopefully it’s visible on my phone pic.
Old Oct 2, 2018 | 12:02 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Good troubleshooting. I like the way the members of this forum assist each other. If you go with DavesMeanE's fittings and lines please take photos.
Old Oct 2, 2018 | 01:35 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I had a oil leak problem earlier this year, but it came from the oil cooler return lines, the o-ring seals failed.
Most of my oil spray was contained to the engine belly pans. So not a tremendous amount of clean-up involved.
Old Oct 2, 2018 | 03:44 PM
AmgAnt's Avatar
2005 E55 AMG
Oh trust me that’s definitely where it’s coming from! Same exact spot as mine and about the same size tear. I took my factory lines off and had new hoses and fittings installed locally here in MD. Hopefully you can fix it soon!
