Check engine light on
Can anyone shed any pearls of wisdom as to what I may need to do, check, change?
Cheers,
Graeme
You said someone did a quick-test with Star diagnostics. Did they give you any printouts? Anyone who knows what they're doing should be able to tell easily which fault turned on the CEL and exactly when each fault was set (freeze frame data). You can tell which fault turned on the CEL just by looking at the print-out from the quick-test (it will have a little light-bulb icon on the right side). To see freeze frame data you simply go into the control unit (ME) and select the fault (or print the faults and it will prompt you to print freeze frame data too).
Without more info, it's kinda hard to give you a diagnostic path. You have two completely independent faults and only one of them is relevant to the current CEL. The purge valve code could be nothing or you might need a new purge valve. The intake air temp fault code could be caused by a bad intercooler pump so I would look into that first. There has been a lot of discussion on here regarding the symptoms and repair of this problem, so I'm not going to spell it out again, just search for it. In short, the original intercooler pumps on these vehicles are known to fail (a lot!). You may notice a severe lack of power after one or more wide open throttle runs. You may not notice much of anything, depending on how you drive. If it's bad or there is any doubt, replace it with a Bosch "010" pump or similar and be sure to bleed the system properly.
Even though the charge air temp fault does not appear to be the one that turned on the CEL, I would still double check your intercooler pump because that is a very common problem. (Just because the CEL isn't on for that fault doesn't mean that it's not also relevant.)
