New E55 Owner
So just picked up a 03 with 79k miles and a few mods. I am looking into going methanol injection since i live in the hot FL heat. I have a few questions on this however. I am not trying to increase power i just want to have it run as safe as possible and not have heat soak. Will i need a retune to run methanol? Do i need to add fuel for this? New injectors wont be required? Def dont want to lean it out!
Sorry for the questions, ive never done meth before LOL Some info on it below. Eurocharged lower pulley Eurocharged headers Eurocharged ecu / tcu tunes LSD rear end Transmission conductor plate and plug update Upgraded tranny cooler Rear Tank https://images.craigslist.org/01414_...X_1200x900.jpg |
Originally Posted by Drew Durham
(Post 7568822)
Sorry for the questions, ive never done meth before LOL Some info on it below. Eurocharged lower pulley Eurocharged headers Eurocharged ecu / tcu tunes LSD rear end Transmission conductor plate and plug update Upgraded tranny cooler Rear Tank https://images.craigslist.org/01414_...X_1200x900.jpg To answer your questions about the meth. No you don't want to tune for the meth setup, so that current tune will stay. Yes it will be safer running with the meth regarding AFR's as you will richen up, provided you have some sort of meth % in your mix. No you will not need new injectors either. Post up your install as you go. Gl |
What size pulley(s?) are you running? With a trunk tank and mild pulley, water/math is probably overkill. What kind of IATs are you seeing? With any normal pulley combo, a trunk tank, and a good tune, you will be a lot safer without water/meth. Even a properly installed system can fail and hydro-lock your engine (although with the proper safeties: check valve and/or solenoid, this is unlikely).
If done right, water/meth can help reduce excessive IATs brought on by aggressive pulleys, but the only way it will give you power is by preventing timing cut due to excessive IATs. Unless your IATs are out of control, it will almost certainly cost you power unless you tune for it (by removing fuel). Tuning for water/meth on a daily driver like this is extremely dangerous because a failure of the system (or just running out of meth) will most likely result in catastrophic engine failure (also, I don't think any of the tuners with experience on this platform would even be willing to do that because of the risk). You need to do a lot more reading on the subject before you even consider water/meth. But, to answer your questions: No, you will not want to tune for it. No, you will not need different injectors. No, you do not add fuel. No, it will not make you go lean (assuming you don't tune for it). Methanol is fuel so you will be running very rich on it (hence the potential loss of power). |
