Which fuse is best to tap into for cwa100?
Old Nov 4, 2018 | 01:28 PM
MACEDON's Avatar
05 E55, 98 CLK320
I want to take the guesswork out of this, can you guys recommend me which position would be best in the front driverside box?
Old Nov 4, 2018 | 01:58 PM
tlambert's Avatar
2005 E55 AMG
I read it somewhere in a thread for installing an aftermarket pump along with adding the ice tank in the trunk maybe?
Do do a search for trunk tank install and you should run across the info.
Old Nov 4, 2018 | 02:45 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
I used an add a circuit on the 25A(I think?) next to the two 15A fuses on the front passenger side of the engene bay fuse box. It's unused you can find it on the fuse chart.
Old Nov 4, 2018 | 08:47 PM
mbmg's Avatar
2004 E55
15amp fused "add a fuse" tap on fuse 54 (Cig Lighter) in the front SAM. I used the middle and left socket that turns on with ign.
Old Nov 6, 2018 | 12:45 PM
MACEDON's Avatar
05 E55, 98 CLK320
So I ended up using that 25A fuse, but I can't figure out why that fuse had power on it with the key off when I put the multimeter across it... it's just not adding up.
Old Nov 6, 2018 | 05:51 PM
mbmg's Avatar
2004 E55
Which fuse are you using in the photo below? If you are tapping into one of either fuse 54 or 53 and use the far left (passenger side) socket you will get +12v acc power (only on with ignition). If you use one of the far right (driver's side) sockets in those fuses, you'll get +12v constant. To get ign from one of those fuses you'll either need to move the fuse to the right orientation and use a male spade terminal on the left socket, or you'll need to use a fuse tap and make sure it's on the far left socket and fuse blade.
Old Nov 8, 2018 | 09:03 AM
MACEDON's Avatar
05 E55, 98 CLK320
I used the one that says 25 on it, I used an add a fuse kit, 12 gauge wire, crimping tool, and these WAGO terminals to join all the wires together. I'll snap some photos of the set up.
The fuse is that white one towards the bottom.
Old Nov 8, 2018 | 12:07 PM
mbmg's Avatar
2004 E55
My fuse diagram shows that you used fuse 57 which is listed for CDI control unit for engines 646, 647, 648. I have a 04 E55 and I just now tested fuse 57 and I don't get any volt reading with the car off or on. I would suggest you move your add-a-fuse to fuse 54 cigarette above and make sure that it is in the far left position (towards passenger side of car).
Old Nov 9, 2018 | 01:16 AM
drothgeb's Avatar
Veteran: Navy
2005 E55
The 25A is unused, keyed power, and I have been using it for over a year for both my methonal pump(with an Led indicator in the cab during operation) and one of my intercooler pumps.
.... at least on my 05.
Old Nov 9, 2018 | 08:37 AM
mbmg's Avatar
2004 E55
There must be differences then on some model year E55s and/or as equipped for that fuse 57. I have the 25amp fuse but no power in any ign circumstance.
